Pocket GPS World :: View topic - antenna
antenna
resarf
PostPosted: Thu Oct 27, 2005 6:27 pm    Post subject: antenna Reply with quote
I see some antennas on ebay for under 20 pounds.
Anyone tried them.
FriendlyBloke
PostPosted: Thu Oct 27, 2005 10:09 pm    Post subject: Reply with quote
yep, i have one. Works perfectly.
resarf
PostPosted: Thu Oct 27, 2005 10:24 pm    Post subject: Reply with quote
There is two on ogger at the moment one looks like it has a plastic cover the other is metal .
Which do you have there is no names on them.
FriendlyBloke
PostPosted: Thu Oct 27, 2005 11:42 pm    Post subject: Reply with quote
hmm, whichever you go for make sure its waterproof, i'd stay clear of metal?? My one is the same as item no. 5823601887. Hope this helps
resarf
PostPosted: Fri Oct 28, 2005 12:50 am    Post subject: Reply with quote
Thanks My thoughts were the same the insulated one looks the best bet.
FriendlyBloke
PostPosted: Fri Oct 28, 2005 3:33 pm    Post subject: Reply with quote
.........£9.68 Wink
zogman
PostPosted: Fri Oct 28, 2005 4:15 pm    Post subject: Reply with quote
if you dont want to part with your money over the web and want to see one before you buy , maplins have gps antennas for £19.99...
spaddy
PostPosted: Mon Nov 28, 2005 9:42 am    Post subject: Re: antenna Reply with quote
Just bought one from ebay company called northstar_gps
$19.95 us. Hooked it up to my I5 and right away 5 green bars.
It is worth every penny.
Anyone tried them.
Mr_Gonzales
PostPosted: Mon Nov 28, 2005 12:12 pm    Post subject: Reply with quote
comet are selling the Garmin GA27C antenna for just £21.99 if you want to go official. Search for i3 on their website, then select the i3 and it'll come up under accessories. Way cheaper than Garmin are selling it for, I think.
thepotter
PostPosted: Tue Nov 29, 2005 12:25 am    Post subject: antenna Reply with quote
I bought one for £19.99 from Maplins. It works a treat.
London_i3_Newbie
PostPosted: Tue Nov 29, 2005 1:48 pm    Post subject: Reply with quote
i just bought a garmin GA26/27 antenna suction mount and realised you can only attach a genuine garmin aerial to it using screws the surface ISNT magnetic aswell fat load of good Confused
Ive bought an aerial off ebay.
Can anyone help me find a windscreen suction holder that grips an aftermarket aerial that IS magnetic Sad
Have looked on ebay but cant find one
Many thanks for ur help
Garmin StreetPilot i3
Software Version 2.50
Audio Version 2.00
Map: City Select Europe NT v7
POIs Uploaded: Speed Camera Data
Mr_Gonzales
PostPosted: Tue Nov 29, 2005 5:16 pm    Post subject: Reply with quote
Dan_Gleebitz wrote:
You can only buy this with the i3. It will not let you buy as a seperate item. In fact if you search for the antenna item number it draws a blank.
Nope, he bought it last week (having already bought the i3 from Argos) and it arrived today. Works well too - at least, it gets a signal indoors at work where it couldn't get a signal before.
He did order it over the phone though - just checked it out on the web. He was trying to get it sooner by using the phone - same price though.
Looking at the website, I think they've made a mistake in that it can only be bought as an accessory (it vanishes when you deselect the i3 itself) they'll sell it on it's own if you give them a call.
Mr_Gonzales
PostPosted: Tue Nov 29, 2005 10:27 pm    Post subject: Reply with quote
How bizarre... guy at work showed me what he'd done on the PC to just get the antenna, having sworn he had managed to select it on it's own on the website...
Select the i3, then add the antenna as an accessory, then in your basket, set the number of i3's to zero, and hey presto, you have just the antenna.
Be nice if they designed it so you could buy it in an easier way!
jackboy
PostPosted: Tue Jan 03, 2006 1:13 am    Post subject: Reply with quote
What's the maplin's one for £19.99?
The one i've seen in the catalogue is abotu £60
dmc
PostPosted: Tue Jan 03, 2006 8:39 am    Post subject: Reply with quote
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=A47FH%20&ModuleNo=48721&doy=3m1
