Pocket GPS World :: View topic - Help with a place that is not listed on my i3
paulmccollam
PostPosted: Fri Oct 21, 2005 1:48 pm    Post subject: Help with a place that is not listed on my i3 Reply with quote
Hi all, Can anyone tell me is there a way of adding a place that is not listed on my i3?
I want to add a place called smugglers creek which is a wee place in Co. Donegal Ireland called Rossnowlagh, near ballyshannon.
Any help would be apprieciated
Paul
zogman
PostPosted: Fri Oct 21, 2005 1:57 pm    Post subject: Reply with quote
the only way i can think of is to use a program called mapsource which comes bundled with metroguide software..(not free !)...you find the place you want on the maps make a waypoint and download it to the i3...or actually go to the place and mark it on the i3 favorites....
paulmccollam
PostPosted: Fri Oct 21, 2005 2:00 pm    Post subject: Reply with quote
thanks zogman...... I didnt relise that if you were in a particular spot you could add that location and name it and then save it to your favorites.
I'm I right in thinking that is the case??
Also is there any free software out there that I could try adding a location that you know off?
Many thanks,
Paul
charlies
PostPosted: Fri Oct 21, 2005 2:19 pm    Post subject: Reply with quote
To add a place, hold the scroll whell in and it will save to favourites, you then name it.
Another possible way would be to create a POI file with the co-odinates in and navigate by using custom points.
paulmccollam
PostPosted: Fri Oct 21, 2005 2:27 pm    Post subject: Reply with quote
thanks very much, can you tell me how to use custom points? Do I need additional software ??
Paul
Almahadeus
PostPosted: Fri Oct 21, 2005 2:31 pm    Post subject: Reply with quote
Paul
Hi Paul, Loads of threads on these forums about how to install and creat POIs. Just have a look in the Garmin Streetpilot forum. Wink
charlies
PostPosted: Fri Oct 21, 2005 11:44 pm    Post subject: Reply with quote
If you download some POI files from MaFt's site and open the CSV files you can see the format.
You could then get co-ordinates from mapsource?...and create your own CSV POI file.
22.044 (24 Apr 24)
