FriendlyBloke Occasional Visitor
Posted: Fri Oct 14, 2005 7:57 pm Post subject: Keeping the same map scale [i3] |
Does anyone know if there is any way of keeping the same map scale no matter what speed you're going? If I zoom to the desired scale, it will stay for a few seconds and then default to its own scale.................bit trivial I know, but also mildly irritating. |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Fri Oct 14, 2005 10:25 pm Post subject: |
try zooming to the scale you want and then press the roler wheel ,you will here a bleep and when i've done i preety sure its stayed at its setting... _________________ *************************** |
Giordino Occasional Visitor
Posted: Fri Oct 14, 2005 11:56 pm Post subject: |
Yes, mine does it too ... although I only noticed it happening since upgrading from version 2.3 to 2.5 (same in 2.6). As with you, it's not a major issue, but is becoming more annoying as I did like to keep it on maximum zoom all the time. Not sure if it now automatically switches after a certain time or speed or if it's a bug in this version (I would suspect bug as it makes the zoom option a bit pointless having to keep resetting it every few minutes).
I think I'll ask Garmin Tech Support about it anyway. |
pauljmuk Occasional Visitor
Posted: Sat Oct 15, 2005 12:43 am Post subject: |
Zooming in suits me personally. Bothered me at first, but now I set map detail to the one above medium. It zooms in and out just enough for me now, and I still see the roads that used to dissapear above average speeds.
Anyway, back to the question - not convinced the pressing of the button does lock the zoom actually.... |
Cuppa Occasional Visitor
Joined: Sep 09, 2005 Posts: 19 Location: East Midlands
Posted: Sat Oct 15, 2005 2:04 pm Post subject: |
I noticed this also. I used to set it more zoomed in and then forget it when I first got it (v2.1). It rememered the last zoom setting when I switched it off and on again. When I upgraded to later versions it just seems to ignore what you do, keeps it a few seconds then does it's own thing. _________________ Cuppa
___________________________________
Audi A2 + Garmin i3, Audi A4 + Garmin i3 |
