dibblecorse Occasional Visitor
Posted: Wed Oct 12, 2005 11:01 pm Post subject: I3 - Setting the time ?? & My home post code is wrong ?? |
Ok, hello, 1st post here so cards behind he bar and virtual drinks are on me ...
I picked up an I3 earlier, have upgraded the firmware, uploaded the latest POIs from MaFt (cheers) but for the life of me can't get the time right ...
Any simple instructions for a numpty ??
Also my home post code gives me the road thats one down from me ... any clues on that ??
Thanks in advance ....
Dibble |
LucyAkhurst Occasional Visitor
Posted: Wed Oct 12, 2005 11:02 pm Post subject: |
the time is picked up from the gps satellites and is a combination of your time zone and daylight saving settings.
Lucy |
Posted: Wed Oct 12, 2005 11:05 pm Post subject: |
ok, so on that basis, and the fact that i'm in my flat in London, what should my settings be Lucy ???
Thanks by the way ... |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15144 Location: Bradford, West Yorkshire
Posted: Thu Oct 13, 2005 12:35 pm Post subject: |
dibblecorse wrote: | ok, so on that basis, and the fact that i'm in my flat in London, what should my settings be Lucy ???
if you stand outside with the unit turned on it will detect the satellites and sort out the time. also, in settings there is an option to select 'auto' for the daylight saving
MaFt |
Willie_Ekaslike Occasional Visitor
Joined: Oct 10, 2005 Posts: 20 Location: Watford, Herts
Posted: Thu Oct 13, 2005 12:45 pm Post subject: |
Although still a newbie myself I think there is an option to save your present location, so just stand outside you flat, save your location and then save that as your home setting (I think)...
I'm sure someone will correct me if I'm wrong. _________________ Willie ~0^0~
ERROR: Keyboard not attached, Press F1 to continue. |
Posted: Thu Oct 13, 2005 12:54 pm Post subject: |
yes, if you have the satellites acquired you can hold the scroll-wheel down and save it as a favourite - rename it to 'Home' and this will be set as home for when you press 'Go Home'
MaFt |
