Pocket GPS World :: View topic - Beginner’s Guide
Beginner’s Guide
Goto page Previous  1, 2, 3, 4, 5 ... 31, 32, 33  Next
PostPosted: Sat Aug 13, 2005 12:12 am    Post subject: Reply with quote
So whenever you find one, send in the speed to Cameras AT PocketGPSWorld.com and next month there will be less "TBAs" :D
smokeygt4
PostPosted: Sun Aug 14, 2005 12:52 am    Post subject: Reply with quote
im trying to install it on my asus a620bt but im going wrong some where Embarassed
i have Destinator 3 installed what files do i have to use and where do they go
thanks
PostPosted: Sun Aug 14, 2005 8:52 am    Post subject: Reply with quote
Darren - have a read of this.
smokeygt4
PostPosted: Sun Aug 14, 2005 8:09 pm    Post subject: Reply with quote
Thanks ive got it working now :D
Darinder
PostPosted: Thu Aug 18, 2005 11:02 am    Post subject: Does single file version contain the lot? Reply with quote
Hi guys,
Quick one - Does the the single file version of the speed cameras contain everything (i.e. different cameras AND the speed zoned cameras) or just the different camera type locations?
Thanks in advance for your help!
PostPosted: Thu Aug 18, 2005 11:11 am    Post subject: Re: Does single file version contain the lot? Reply with quote
Darinder wrote:
Hi guys,
The single file contains the same data but NOT seperated into speed zoned categories.
grasuk
PostPosted: Fri Aug 19, 2005 4:23 pm    Post subject: Loading Speed Camera into Destinator3 Reply with quote
Has anyone got any simple instructions how to do this.
Graham
PostPosted: Fri Aug 19, 2005 4:38 pm    Post subject: Reply with quote
Read the beginners guide.
PostPosted: Fri Aug 19, 2005 7:34 pm    Post subject: Reply with quote
Don't think that will help him Darren. Did you see his post subject "Loading Speed Camera into Destinator3"?
Never heard of it, so I'm no help though!
mogwairacer
PostPosted: Tue Sep 06, 2005 7:22 pm    Post subject: Reply with quote
I have a Garmin Ique 3600 - what files do I transfer to my SD card and how do i get them to display on the maps? (I have read the beginners guide and it's not too obvious - to me anyway!))
Thanks in advance
PostPosted: Tue Sep 06, 2005 7:33 pm    Post subject: Reply with quote
Thanks in advance
I believe it's not easy but this thread shows how - http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=96884
netwave
PostPosted: Wed Sep 07, 2005 8:44 pm    Post subject: Frame rate Slowing up! Reply with quote
I have added the following to the Great_Britain_Plus-Map folder...
1. pocketgps_uk_gatso_20
2. pocketgps_uk_gatso_30
3. pocketgps_uk_gatso_40
4. pocketgps_uk_gatso_50
5. pocketgps_uk_gatso_60
6. pocketgps_uk_gatso_70
7. pocketgps_uk_gatso_tba
8. pocketgps_uk_mobile
9. pocketgps_uk_redlight
10.pocketgps_uk_specs
11.pocketgps_uk_temp
Also added was the voice warnings data.chk File to:
My Pocket PC/Program Files\Navigator
Everything has been configured & worked 1st time, thanks to some very clear Tutorial's supplied thanks !!
However I have 1 query...
Since copying the above to the Great_Britain_Plus-Map folder ,I have noticed a drop In framerate when the arrow is moving along the map!
It now performs more like TT3
When I delete the above out of the GB+ folder the Framerate is super smooth again without any jitter?
Obviously in my case,adding additional data to this folder causes framerate loss!
Is their a way boosting up the framerate to compensate?
I have defraged the SD card under XP but this has made little difference to the overall performance.
Are their any other ways of getting cam warnings without performance loss?
Cheers.
PostPosted: Wed Sep 07, 2005 9:56 pm    Post subject: Reply with quote
There will be some improvement if you Disable the categories in Enable/Disable, but leave the Warn When Near On.
Then you only lose the icons on the Browse Map, and still get the warning icon when travelling.
netwave
PostPosted: Wed Sep 07, 2005 11:56 pm    Post subject: Reply with quote
Yep That did the trick! Thanks Richard
arjun
PostPosted: Thu Sep 29, 2005 8:10 pm    Post subject: Reply with quote
sorry to be a nuisance. I am a bit new in this field . I do understand you need .csv files for destinator3 in Acer N35 . How do I actually install it?
Page 4 of 33
22.051 (01 May 24)
