AndyCr15 Regular Visitor
Posted: Wed Jun 15, 2005 6:23 pm Post subject: |
Sorry, the other question would be... if I make one and it all goes wrong, can I just delete (or rename) the folder and it will go back to the default menues? _________________ TomTom 6 - SPV M5000 and WM6
Garmin Zumo 500 on Honda TransAlp
www.lanarchy.co.uk for LAN gaming near London |
newmikey Occasional Visitor
Joined: Jun 14, 2005 Posts: 30 Location: Netherlands/Luxembourg
AndyCr15 wrote: | Should there already be a tomtom.mnu file anywhere? Like a default one or something? Or are we creating the sdk folder and then the menu file from scratch as it were?
I would prefer to have the default one, and then cut and paste a few commands as needed |
No, the whole directory typically doesn't exist! One advantage: do something wrong -> just delete the TomTom.mnu file and you have your default menu back.
Therefore:
1. You are creating a directory SDKRegistry from scratch
2. You are creating a file TomTom.mnu from scratch and move it into the directory created under (1)
3. You use this file http://www.pocketnavigation.de/board/attachment.php?attachmentid=16723 as TomTom.mnu
4. Take care to leave exactly one (1) carriage return/linefeed after the last item. Do not insert empty lines!
5. Move items around at will, but never more than five(5) under one submenu heading.
My number 5 menu:
soweezy Pocket GPS Verifier
Posted: Wed Jun 15, 2005 6:33 pm Post subject: |
just tried it, created the SDKRegistry folder in Pocket PC/TomTom, created the TomTom.mnu file using the above code and notepad, loaded it and hey presto...
big thanks to the OP _________________ SW
Garmin Zumo 390LM |
Posted: Wed Jun 15, 2005 6:35 pm Post subject: |
AndyCr15 wrote: | Sorry, the other question would be... if I make one and it all goes wrong, can I just delete (or rename) the folder and it will go back to the default menues? |
saw your post so tested it and yes, deleting the new folder and or file reverts back to the original menus _________________ SW
Garmin Zumo 390LM |
jweaver Regular Visitor
Have Palm users really got this working?
I have just checked, double checked and tripple checked and its just not working for me.
I even added a single CR/LF at the end of the file, as you suggested above, but its still the same!
As per your suggestion, I have deleted the file.. Recreated a new one and put in YOUR config, exactly as you have shown it..
Can you confirm that you have read for sure that this works on the Palm?
Jon |
Posted: Wed Jun 15, 2005 6:41 pm Post subject: |
soweezy wrote: | just tried it, created the SDKRegistry folder in Pocket PC/TomTom, created the TomTom.mnu file using the above code and notepad, loaded it and hey presto...
big thanks to the OP |
YEAHHHH! Congratulations! Now lets see everyone go back to their preferred taste of menu.
I just switched to English for some screenshots, again on my pbase gallery at http://www.pbase.com/newmikey/crops
The English ones are Menu1_en through Menu7_en
My number three menu in English:
Posted: Wed Jun 15, 2005 6:47 pm Post subject: |
What have I done wrong, I just got the error 'SDK ERROR! iNrArguments>0' when I tapped to bring up the menus... _________________ TomTom 6 - SPV M5000 and WM6
Posted: Wed Jun 15, 2005 6:54 pm Post subject: |
AndyCr15 wrote: | What have I done wrong, I just got the error 'SDK ERROR! iNrArguments>0' when I tapped to bring up the menus... |
Happened to me too. Typically that would be a [space] inserted at the wrong place, too may items under one menu page, a missing "|" in a line or 2 CR/LF's at the end of the file.
Trash the file and start again.
I'm going to sign off, exhausted. From far away Luxembourg I wish you all a pleasant evening! |
Posted: Wed Jun 15, 2005 7:01 pm Post subject: |
NewMikey
any chance you can translate the dutch (I assume it's Dutch) into English ?
Altavista's Babel Fish wasn't much help _________________ SW
Garmin Zumo 390LM |
Posted: Wed Jun 15, 2005 7:03 pm Post subject: |
where's the edit button when you need it ?
Basisnavigatie
Uitgebreide navigatie
Favorieten en POIs
Systeeminstellingen
Kleuren, maten en taal
Diversen
Voorkeuren
thanks... _________________ SW
Garmin Zumo 390LM |
I_Need_Help Regular Visitor
Posted: Wed Jun 15, 2005 7:04 pm Post subject: |
Great thanks works fine.
At first I got the error iNrArguments > 0
But after playing around (cutting and pasting the file from the link http://www.pocketnavigation.de/board/attachment.php?attachmentid=16723)
The folder doesn’t exist by default create in the root \TomTom\SDKRegistry
( the tomtom folder should exist)
When first crating the mnu file in notepad and saving it you may end up with tomtom.mnu.txt so you need to rename it to tomtom.mnu
I can now change the menus thanks
Can you insert 1 new menu at the beginning and all the default menus be linked form it? |
julianbarker Lifetime Member
Posted: Wed Jun 15, 2005 7:15 pm Post subject: |
Works well on m yPPc - to translate into English, just delete alL the Dutch iN the file - the English text is the default and is used if no alternative text is supplied in the .mnu file. |
Posted: Wed Jun 15, 2005 7:30 pm Post subject: |
hmmm... deleted the Dutch and now there's nothing in the headings [scratches head] _________________ SW
Garmin Zumo 390LM |
Spark1e Banned
Posted: Wed Jun 15, 2005 7:39 pm Post subject: |
soweezy wrote: | where's the edit button when you need it ?
Basisnavigatie
Favorieten en POIs
Systeeminstellingen
Diversen
Voorkeuren
thanks... |
You can just re-name them to whatever you like :D |
Spark1e Banned
Posted: Wed Jun 15, 2005 7:43 pm Post subject: |
Damn - can't edit
Great post newmikey, thanks very much for this :D :D |
