atters Occasional Visitor
Posted: Thu Feb 03, 2005 2:50 pm Post subject: Deleting foreign voices |
I have a TTG with the 128Mb SD card supplied. I would like to delete the non English voises from the card to make space for the safety camera data files. Can anybody advise on which files I can delete and where they can be found?
Atters |
hemantp Occasional Visitor
Posted: Thu Feb 03, 2005 2:54 pm Post subject: |
You can use the CD provided with the TTG... hook it up via the USB cable provided with your PC. And you'll see the option to add/remove the voices. _________________ .h
a l w a y s a p l e a s u r e . . .
. . . n e v e r a c h o r e |
boris Occasional Visitor
![](modules/Forums/images/avatars/gallery/simpsons7.jpg)
Posted: Thu Feb 24, 2005 12:43 am Post subject: |
Hi.
I deleted the foreign voices and that clears plenty of space - BUT - not enough space if you then find you want to add on the postcode search which is REALLY useful. So, just bought a Kingston 512MB card, and hope to get it all swapped over. (Just found out I need a reader/writter before I can do that though). I suppose point is, I think you may well end up using a 'bigger' card anyway... |
Oldboy Pocket GPS Moderator
Posted: Thu Feb 24, 2005 7:53 am Post subject: |
boris wrote: | So, just bought a Kingston 512MB card, and hope to get it all swapped over. (Just found out I need a reader/writter before I can do that though). I suppose point is, I think you may well end up using a 'bigger' card anyway... |
No, you don't need a reader.
Connect TTG to PC, as detailed in handbook, and drag all the contents of the 128 card to a temp folder on the PC.
Switch off TTG, swap cards, switch on TTG and copy every thing from the PC back to the card. That way you won't have to activate again. _________________ Richard
Posted: Thu Feb 24, 2005 10:08 pm Post subject: |
Hi.
Oldboy you are a true TomTom GOD!! :P
Trouble is, just before comming on the forum tonight I ordered a reader from Dabs!!!! I read your reply, and the laptop is now busy copying in the way you advised! MAGIC can't thank you enough.
Now I will have ALL cameras, and hopefully due to the Kingston 512, ALL postcodes. Sorry for my muppetry
boris |
![](modules/Forums/images/avatars/32928398450ec149ec6abd.gif)
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Thu Feb 24, 2005 10:26 pm Post subject: |
Hi Boris,
Don’t worry about buying the card reader. I would expect that you can transfer data much quicker via a card reader than via the TTGO.
I can copy/write nearly 1GB of data to and from a CF card in just over 4 minutes. Before I had a card reader, installing a map of 100MB via MS ActiveSync would take about 20 to 25 minutes.
Garmin Camper 770 LMT-D |
Posted: Thu Feb 24, 2005 10:38 pm Post subject: |
Privateer wrote: | Hi Boris,
Regards, |
To install the France Map on to a SD card while in the TTG takes about 22 mins.
I suppose it's down to a question of convenience and choice. _________________ Richard
