Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 46, 47, 48 ... 72, 73, 74  Next
PostPosted: Fri Mar 31, 2017 10:18 am    Post subject: Reply with quote
New version 63.
Just a minor change on the 'Text Change' screen.
There was a Tab order issue that forced the Allow Prefix radio button to always be selected when the screen was opened.
Works OK for me but feedback please.
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0
Satnav:
Car Average MPG :
cottonsocks
PostPosted: Mon May 01, 2017 12:13 pm    Post subject: Reply with quote
The overspeed warning is sometimes being given when well under the speed limit. I have changed the overspeeds to 1 mph above the official limit, but it's still doing it. Is this a bug by any chance?
PostPosted: Mon May 01, 2017 1:13 pm    Post subject: Reply with quote
Not a bug my end.
If you have the overspeed set then I write out a standard GPX line that contains a @ symbol.
That is what Garmin works with.
Your debug steps:
Find any camera in question in the speed related file it's in. Once found copy and paste the individual camera line(s) here so I can investigate it and whether it's the same in my file.
Satnav:
Car Average MPG :
cottonsocks
PostPosted: Mon May 01, 2017 4:25 pm    Post subject: Reply with quote
Kremmen wrote:
Not a bug my end.
Your debug steps:
Sorry but I'm not sure what you want me to do. Can you give me some precise steps to follow?
PostPosted: Mon May 01, 2017 6:12 pm    Post subject: Reply with quote
What's the camera number of any one you are having an issue with ?
...and what speed is it ?
Satnav:
Car Average MPG :
cottonsocks
PostPosted: Mon May 01, 2017 9:07 pm    Post subject: Reply with quote
It's certainly doing it with MOBILE (ID:21292) which is a 30mph mobile camera and it also happened with MOBILE 30469@40 heading out of Worcester.
Does that help?
PostPosted: Tue May 02, 2017 5:35 am    Post subject: Reply with quote
OK, when I'm at the PC later I'll see what they are writing.
Satnav:
Car Average MPG :
PostPosted: Tue May 02, 2017 12:58 pm    Post subject: Reply with quote
As expected they are fine:
S-MOBILE:21292#30
S-MOBILE:21292@30
Under my settings of 14 and 5 seconds the proximities are 187 and 67 yards respectively, which is correct.
SE-MOBILE:30469#40
SE-MOBILE:30469@40
250 and 89 yards.
Conclusion, your Garmin thinks you're speeding, or, you are accelerating at a rate that the Garmin thinks you will be speeding when you get to the camera.
Satnav:
Car Average MPG :
Oscargrouch
PostPosted: Tue May 02, 2017 11:38 pm    Post subject: Reply with quote
I am sure you are correct Kremmen; the one thing I feel that must be remembered is that we are not using GPS in what's known as a DGPS. Wink What may be happening, is that there is a sudden jump forward which might be indicating an increased speed. Just food for thought... At the end of the day; the programme you have made available is Brill; always better to vere on the safe side....Very Happy
Garmin Nuvi 2599 LMT-D
dales
PostPosted: Wed May 03, 2017 12:10 am    Post subject: Reply with quote
The latest version of AVG Free is a pain.
It flags the Direction Converter up as Suspicious, but eventually lets it run.
It flags the CSV Converter up as Suspicious, and says it is reporting it to HQ for analysis and approval, which is never forthcoming. Meantime, it will not let it run.
The answer is to go into AVG Settings and to Resident Shield and Customise and Exceptions and browse to the location of the converter.exe and set it to be not scanned eg C:\Users\Dales\AppData\Local\Apps\2.0\etc.
Dales.
PostPosted: Wed May 03, 2017 5:53 am    Post subject: Reply with quote
That has been raised before and the AVG whitelist route was suggested.
Malwarebytes ransomware also flagged it. The reason is because it's deleting csv files and rewriting them as gpx files, rather quickly. Similar behaviour as some ransomeware viruses.
If anyone wants a copy of the source code you are more than welcome. Nothing to hide.
Satnav:
Car Average MPG :
dales
PostPosted: Fri May 05, 2017 7:07 pm    Post subject: Reply with quote
I've just had a message back from AVG
"AVG Virus Lab says this file is clean - CSV to GPX converter.
The larger our database, the better we can protect you".
So it seems it will not block it in future, because marked safe in the database.
PostPosted: Fri May 05, 2017 7:10 pm    Post subject: Reply with quote
Luvvly Jubbly
I promise not to stick a mickey in there Very Happy
Satnav:
Car Average MPG :
PostPosted: Thu May 11, 2017 6:44 am    Post subject: Reply with quote
Info:
Malwarebytes v3 has started identifying the Converter as Ransomware Sad
As before, you will need to add it to the exclusions list (amend your 'hyroglyphic' filename as required).
I've emailed MBAM but I'm not expecting any positive outcome.
Also - Norton blocked it this morning Rolling Eyes
The Norton fix is via 'Scans - File Insight' then 'Trust' the program:
Odd they should both block it on the same day. Are they in collusion (not a bad thing).
Satnav:
Car Average MPG :
PostPosted: Tue Jul 04, 2017 11:48 am    Post subject: Reply with quote
Notice
A new version is on its way due to one bug and one enhancement. (thanks M) Smile
Since I last compiled the project, Microsoft in their infinite wisdom, have updated all versions of C:\Windows\System32\Shell32.dll (and the SYSWOW entry for 64bit). They are now dated May 2017 (for Win7) and June 2017 (For Win10).
The various versions across Windows platforms are now not compatible with each other !!!
Unfortunately the error message was as clear as mud:
The end result is that the UnZip routine, that uses the Shell command will only work natively on Win7 machines that have the same .dll that I have.
However, .Net 4.5 framework has a new ZipFile class that I have rewritten into, so with the next version (64) you will need .NET 4.5 installed. Currently the requirement was 4.0
If you haven't got 4.5, or newer it should prompt a download.
Repeat after me - "I hate Microsoft"
Satnav:
Car Average MPG :
Page 47 of 74
22.055 (29 May 24)
