Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Sat Nov 18, 2006 11:35 pm Post subject: |
What does it say when you try to open an .asc file? _________________ Tim |
nav-man Occasional Visitor
Posted: Sat Nov 18, 2006 11:54 pm Post subject: |
I am sure I have tried that, but it will try it again.
I will come back and let you know how I get on.
Cheer's |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sun Nov 19, 2006 11:55 am Post subject: |
barrados wrote: | nav-man wrote: | I have but the new N Series poi editor needs it to be in CVS format |
Just use poi edit and convert the files from one format to .csv format. |
I did this and the Desktop reported files successfully downloaded to the device. I saved them on the internal memory as the files are so small rather than on the SD card.
They appear on the Navman screen with the names I allocated to the files (and they are in bold text indicating they are activated) but when I went for a drive none of them showed up or gave any warnings.
Is it possible to use the default icon for all the cameras - I didn't, just used those with the PGPSW download.
There is also a choice of warning sound - again this time I used the default wav file.
Did all yours load and work OK _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Sun Nov 19, 2006 12:13 pm Post subject: |
Tim - see expanded dialog by email.
Graham _________________ Gee-Pee
Posted: Sun Nov 19, 2006 1:23 pm Post subject: |
You can only load CSV files into the N20 POI editor it will not let you load any other type of file unlike the ICN510 POI editor.
Somehow they will have to be changed before.
If we were able to download the safety camera files from Pocket GPS in Excel spreadsheet ( xls ) format I have a programme to convert it to CVS then all would be great
Any sugestions ! |
Posted: Sun Nov 19, 2006 1:27 pm Post subject: |
nav-man wrote: | You can only load CSV files into the N20 POI editor it will not let you load any other type of file unlike the ICN510 POI editor.
Any sugestions ! |
I just opened files in Notepad then 'saved as' *.csv into the same folder which I used to extract them from the zipped/dowloaded file. _________________ Gee-Pee
Posted: Sun Nov 19, 2006 1:39 pm Post subject: |
I just loaded a safety camera file onto note pad as you suggested and then tried to save as a CVS file but you only have the option of saving as a text file which is the same as it a is already. |
Posted: Sun Nov 19, 2006 1:52 pm Post subject: |
nav-man wrote: | If we were able to download the safety camera files from Pocket GPS in Excel spreadsheet ( xls ) ........Any sugestions ! | Only one sugestion, when in the download speed camera options open the dropdown box for the SatNav system and look at the fourth item in the list - Mike |
Posted: Sun Nov 19, 2006 2:07 pm Post subject: |
nav-man wrote: | I just loaded a safety camera file onto note pad as you suggested and then tried to save as a CVS file but you only have the option of saving as a text file which is the same as it a is already. |
In Notepad, select File - Save as then at the bottom of the Notepad screen there should be a dialog box which gives you the opportunity to "Save as type" - select this and take the option to save as "All files" (there should be a 'down' arrow against the box), then on the name of the original file add .csv and save to the same folder where you extracted the files to from the downloaded zipped folder.
[/img] _________________ Gee-Pee
Posted: Sun Nov 19, 2006 3:26 pm Post subject: |
Thank you very much for that Gee-Pee it works great you really know your stuff.
Cheers |
portman Frequent Visitor
Posted: Sun Nov 19, 2006 5:01 pm Post subject: |
Just use the safety camera file for the garmin, poiloader version, works fine as do all other garmin poi's as they are csv. _________________ Samsung Mega
Tomtom 500
Posted: Sun Nov 19, 2006 5:03 pm Post subject: |
If you want more wav sound files use these.
http://www.waveevents.com/
Wave Events - WAV files, _________________ Samsung Mega
Tomtom 500
Posted: Sun Nov 19, 2006 5:12 pm Post subject: |
Thank you, thank you, Portman _________________ Gee-Pee
Posted: Sun Nov 19, 2006 9:53 pm Post subject: |
Just downloaded and installed an extra file, just to see how it works. Dead easy installation and quick through the N20's POI editor - 'My Sounds Admin' - page 96 in the Manual. _________________ Gee-Pee
mostdom Pocket GPS Moderator
Joined: Jul 10, 2006 Posts: 1964 Location: Surrey, UK.
