Pocket GPS World :: View topic - i3 Calibration required or fault?
20vt-rs
PostPosted: Fri Feb 17, 2006 12:12 am    Post subject: i3 Calibration required or fault? Reply with quote
Hi - I've had an i3 for about a month now, not really used it much until this week. I've travelled up and down the M5 and M6 over the last couple of days, and on occasions the i3 seemed to think it was travelling parallel with the motorway, i.e the triangle was left of the M5. This causes the unit to confuse and keep re-calculating whenever you pass a local road.
Does this sound like it needs calibrating, or is there a problem with the GPS signal, or is it faulty?
Thanks in advance.
alix776
PostPosted: Fri Feb 17, 2006 12:19 am    Post subject: Reply with quote
might be low signal strength do your car have a heat reflective windscreen or the unit might need a factory reset
device Lumia 950 xl
20vt-rs
PostPosted: Fri Feb 17, 2006 12:56 am    Post subject: Reply with quote
No the car hasn't got a heated or reflective windscreen, but the unit is mounted to a vent mount and not the windscreen, would that make much difference? It' has full view through the window...
PaulB2005
PostPosted: Fri Feb 17, 2006 9:33 am    Post subject: Reply with quote
Better to put it on the windscreen, although mine carried on working fine from the glove compartment of my car when i popped it in there whilst re-fuelling. Didn't bother to switch it off and then pulled away with this muffled voice coming from the car! It was only when it bonged for a Camera that i realised what I'd done!
What car do you have?
Aitch2
PostPosted: Fri Feb 17, 2006 11:13 am    Post subject: Reply with quote
Make sure that:
1) You're running unit Firmware v2.7
2) You've selected WAAS/EGNOS mode for the GPS
Aitch
Find Somewhere Else 090407: www.marillion.com
Trajet
PostPosted: Fri Feb 17, 2006 3:33 pm    Post subject: Reply with quote
Aitch2 wrote:
Make sure that:
Aitch
I don't think WAAS/EGNOS is fully operational yet!
Aitch2
PostPosted: Fri Feb 17, 2006 4:49 pm    Post subject: Reply with quote
Mine appears to work fine in this mode...
Aitch
Lester_Burnham
PostPosted: Fri Feb 17, 2006 5:44 pm    Post subject: Reply with quote
Aitch
I used it for a while - but then had some funky results with some results, which didn't occur when I set the GPS mode to normal.
I've decided to leave it (EGNOS) off, now, until EGNOS properly goes live.
bumpkin
PostPosted: Fri Feb 17, 2006 7:48 pm    Post subject: Reply with quote
I have mine set up to use the EGNOS signal, it seems to work fine. According to this page (http://www.tracklogs.co.uk/cgi-bin/publ/user.cgi?obj=home&page=gpsfaq&id=2040) it went live almost 2 years ago.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
Lester_Burnham
PostPosted: Sat Feb 18, 2006 10:48 pm    Post subject: Reply with quote
It's NOT live - note the comment "due".
Now me saying it's NOT live, doesn't mean it won't work, or operate in certain locations - merely that's it's not fully implemented, and you may get inconsistent results.
