Pocket GPS World :: View topic - New Garmin i3 wont acquire?
ch1py
PostPosted: Wed Oct 26, 2005 11:25 pm    Post subject: New Garmin i3 wont acquire? Reply with quote
hi,
i purchased a garmin i3 today from argos, updated to 2.6 software and installed all the speed camera and POI's which i found in the first post on this board, respect to who-ever put the post together with the instructions, it was a breeze to follow.
the problem im getting is it wont acquire any signal outside the car or inside, the most i have got is 1 red bar, i made sure i was in the open with clear sky but nothing, i sat there for 1 hour aswell, it was cold!!! Laughing
any help is much appreciated for a noob gps owner.
thanks in advance.
Logan1475
PostPosted: Thu Oct 27, 2005 12:15 pm    Post subject: Reply with quote
Under navigation is your GPS mode set to normal? That is only thing I can think of, am fairly new to this myself.
Have heard on these forums that initially the unit can take a while when first switched on to get all the info it initally needs but an hour seems a little excessive.
If batteries are a run down this can make acquiring take longer also. :|
ch1py
PostPosted: Thu Oct 27, 2005 4:22 pm    Post subject: Reply with quote
it was with new batteries, and the reception is set to gps on in the settings, not waas or whatever it is, strange.
ill try a master reset then go and sit in a field again as its a nice day today, wish me luck. Laughing
Skippy
PostPosted: Thu Oct 27, 2005 4:53 pm    Post subject: Reply with quote
Yeah, a master reset is all I can think of doing. It should get a first fix in about 5 minutes and should have all it's sats in less than 15 minutes.
It's worth waiting around for a 15 minutes because although it can get an initial position fix using 3 or 4 sats, it takes a few minutes more to download the data for all the sats.
Once this has been done, it should get a fix from cold (switched off for > 6 hours) in a minute or two with a good view of the sky.
Older Garmins had a status screen where you could see the visible sats and watch it lock on to each one. Someone mentioned that there was a secret way of getting this screen to appear on the i3, you might want to try it so you can see what's happening.
Oh, and Welcome by the way.
Gone fishing!
ch1py
PostPosted: Fri Oct 28, 2005 2:38 am    Post subject: Reply with quote
done a master reset, and fresh batteries, got a fix in about 10 mins now but when i put it in the car window i loose signal, just ordered a 5 metre insulated antenna from ebay, hope this helps, it's a renault megane coupe if anyone is interested, maybe the screen is insulated?
thanks for the advice.
Skippy
PostPosted: Fri Oct 28, 2005 10:40 am    Post subject: Reply with quote
ch1py wrote:
renault megane coupe maybe the screen is insulated?
It's very likely that it is. Not all Meganes have the heat reflective windscreen but the ones with air conditioning do. Does your windscreen have an odd blue relection and a dark patch around the rear view mirror when viewed from the outside?
If it works through the sunroof or side windows or behind the rear view mirror then that confirms it.
Good luck!
Gone fishing!
ch1py
PostPosted: Fri Oct 28, 2005 12:12 pm    Post subject: Reply with quote
yes, it has a dark patch at the back of the rear view mirror, and a dark rim around the edge of the screen, if i hold it next to the door windows everything is fine.
where would be the best place to mount the external antenna? would the inside of the rear window be ok?
FriendlyBloke
PostPosted: Fri Oct 28, 2005 4:38 pm    Post subject: Reply with quote
see
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=27983
this may be of use??
navitron
PostPosted: Fri Oct 28, 2005 10:58 pm    Post subject: Reply with quote
Just wondering if you know what the secret was Skippy?
navitron
PostPosted: Fri Oct 28, 2005 11:00 pm    Post subject: Reply with quote
Just wondering if you knew what the secret was Skippy?
andspenka
PostPosted: Fri Oct 28, 2005 11:29 pm    Post subject: Reply with quote
Is this a new or old Megane? I've got a new Megane CC and mine works fine, no probs with reception at all.
I think it's more dependant on the model rather than the air con, as my Megane has air con but it still doesn't have a heat reflective windscreen. They are as you say easy to see though by the bluey tinge on the outside.
Andspenka
TomTom One V2
ch1py
PostPosted: Mon Oct 31, 2005 12:10 am    Post subject: Reply with quote
Its a 1999 megane coupe, my external antenna arrived saturday, wired it through to the rear window, within 1 min i had full signal so decided to try it out, drove from the midlands to skegness and i didnt have a loss of signal once!
strange thing was it took me back a different way but it didnt take any longer and it was a nice drive, so im really happy with my purchase.
thanks for all the advice guys. :D
