Pocket GPS World :: View topic - Jaguar XJ Speed Camera Software Add-on? Does it exist?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems
azibux1
PostPosted: Mon Jul 29, 2013 11:15 pm    Post subject: Jaguar XJ Speed Camera Software Add-on? Does it exist? Reply with quote
Hi all,
Does anyone here know of an add-on that would allow the Jaguar system to detect speed cameras?
The dealer mentioned one they usually use in GPX format but after trying for a long time he said it can't be done on this car as it is a 60 plate and it only works on models after that... Not sure how true that is
So does anyone know of anything that will work?
Any help would be appreciated as I've never done anything like this before Smile
Also I hope this is in the right section as it is my first post, if not then can someone pleas move it for me Smile
Thanks in advance
IanS100
PostPosted: Tue Jul 30, 2013 7:56 pm    Post subject: Reply with quote
There's an installation Guide for a 2013 XF that may give you a few pointers, gotta be worth a read either way:
http://www.pocketgpsworld.com/uksafetycameras-jaguar-xf.php
azibux1
PostPosted: Tue Jul 30, 2013 8:01 pm    Post subject: Reply with quote
Thanks I'll check that out Smile
my1690
PostPosted: Fri Aug 16, 2013 12:46 pm    Post subject: Reply with quote
sadly only very late 2012 Jaguar XF models and later work using the guide mentioned above
something to do with the Denso firmware on earlier Jaguars, I belive if enough people complain directly to Jaguar (not the main dealers) then sometime in the future a firmware upgrade maybe available for the older (hard drive based) Denso units, then you will be able to use the GPX consolidated file from PocketGPS
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems All times are GMT + 1 Hour
