Pocket GPS World :: View topic - Voice warnings on Garmin streetpilot c320
mooface
PostPosted: Mon Jun 20, 2011 3:36 pm    Post subject: Voice warnings on Garmin streetpilot c320 Reply with quote
I am trying to get the voice warnings to work on my Garmin streetpilot c320.
If there are mp3 files, they do not play, if there are wav files, the poi loader claims that there is not enough room on the device. I have a 2GB SD card, and the wav files are mono at 44Khz so that should not be the problem. Also I have put sox.exe in the right place.
Anything else to try??
PostPosted: Mon Jun 20, 2011 3:51 pm    Post subject: Reply with quote
Does the c320 have an mp3 player built in, if not AFAIK it won't play the audio warnings, all you get are the bongs - Mike
dales
PostPosted: Mon Jun 20, 2011 4:51 pm    Post subject: Reply with quote
For my own device (not a c320) I can put the files on a 2Gb SD card with loads of room to spare.
I just stick the SD card in a card reader, and PoiLoader detects it as a Garmin device.
Dales.
mooface
PostPosted: Tue Jun 21, 2011 12:59 pm    Post subject: Reply with quote
The message DOES come up on mine.
I don't know if it supports MP3s, but I thought all versions support wavs?
PostPosted: Tue Jun 21, 2011 2:17 pm    Post subject: Reply with quote
I know the voice files, but I don't know the Streetpilot, so I'm only thinking off the top of my head...
I assume you've already looked at the available space on the card and added up the file sizes of everything you are trying to put on it, yes?
If that all seems in order, is there any possibility that POILoader is not "pointing" at the SD card and is still trying to load onto internal memory?
As another experiment, what happens if you just add ONE voice file to the folder you send to POILoader? Does that still complain of not enough space?
"Settling in nicely" ;-)
