Andy_P Pocket GPS Moderator
Posted: Tue Mar 23, 2010 3:24 pm Post subject: |
The SEARCH button above is your friend.....
Try THIS TOPIC for starters. |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Tue Mar 23, 2010 5:58 pm Post subject: |
I agree with everyones comments about Navcore9 - don't use it on a device it hasn't been released for - hang fire and wait.
TT appear to be in a transitional period in regards to the Linux kernel - the x50 range use a different kerne hence why standby and LIVE don't work properly on older devices. |
blackstars Occasional Visitor
Posted: Tue Mar 23, 2010 8:23 pm Post subject: |
mikealder wrote: | A 940 loaded with the Fiat Blue Me Navcore 9 is what you want as this does offer different routes depending upon vehicle type using the standard map, have a look at This
I would suggest you get a 4GB MicroSD card for the software to go on along with a map, once you have got the memory card we can point you in the direction of installing it - Mike |
yeah, ive seen this video, thats exactly what i am after, i have already got a 8gb micro card for my unit, how do i go about installing it onto my micro card ? cheers |
Posted: Tue Mar 23, 2010 8:36 pm Post subject: |
Did you look at the link I found for you above?
The download location and some instructions are in the last two posts on page one. |
Posted: Tue Mar 23, 2010 11:28 pm Post subject: |
Andy_P wrote: | Did you look at the link I found for you above?
thanks for the advice, installed fiat blue me, onto mem card, everything seems to be fine, only prob is, mp3 player not working, lost all my favs and i cannot seem to be able to get rid of the green phone symbol on the left hand side of the screen |
Posted: Wed Mar 24, 2010 12:15 am Post subject: |
If its a 940 running the Blue Me software then the mp3 player should work fine (mine does/ did, as you have seen).
As for the silly icon on the left side of the screen go to change preferences/ quick menu preferences and deselect whatever stupid option TomTom have enabled on the device (probably something to do with the phone) - Mike |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Wed Mar 24, 2010 12:29 am Post subject: |
The only way to get rid of the handsfree green icon using Nav9 on an x40 is either to delete the pairing with the mobile as it will not permanently deselect from the quick menu or to add another item which gives you a different icon to the shortcut menu which is equally annoying. _________________ Drivelux |
Posted: Wed Mar 24, 2010 12:39 am Post subject: |
MrT wrote: | The only way to get rid of the handsfree green icon using Nav9 on an x40 is either to delete the pairing with the mobile as it will not permanently deselect from the quick menu or to add another item which gives you a different icon to the shortcut menu which is equally annoying. |
got rid of phone icon, still no mp3 player though.... |
Posted: Wed Mar 24, 2010 9:16 am Post subject: |
Do you have a mp3d file in the bin folder on the device?
If not, copy one from another Navcore release in to that folder. |
Posted: Wed Mar 24, 2010 4:08 pm Post subject: |
AndyVaughan wrote: | Do you have a mp3d file in the bin folder on the device?
no it did'nt, so copied as you said, working fine now, thank you very much mate.
i do have one very quick question, i hope you could help me with concearning the maps, now i can change the vechicle profiles on the device to truck mode, will the currant maps know where all the low bridges, weight limits are ? or will i need the truck maps ? cheers |
Posted: Wed Mar 24, 2010 6:22 pm Post subject: |
The route is certainly different when using the different vehicle profiles but whether it will avoid low bridges etc I have no idea, for that to work I would expect you to need the Truck maps - Mike |
Posted: Thu Mar 25, 2010 9:19 pm Post subject: |
mikealder wrote: | The route is certainly different when using the different vehicle profiles but whether it will avoid low bridges etc I have no idea, for that to work I would expect you to need the Truck maps - Mike |
had a playaround with the routings whilst in truck mode, and its sending me down roads where the bridge is too low for the truck, so the tt maps does not know where all the bridges are. ive seen somewhere on this site where you can download a low bridges program, if i was to do this, would the tt maps then know where all the low bridges are ? cheers |
Posted: Thu Mar 25, 2010 9:56 pm Post subject: |
You would get a warning from the device for a low bridge POI file as you approach it (if configured for warning against this POI file) but the device has no way to avoid POI so it won't prevent it routing you under such a hazzard - Mike |
Posted: Mon Mar 29, 2010 10:32 pm Post subject: |
since installing fiat blue me, unit has a flat battery, every time i try to switch it on, anybody got any ideas on this one ??? cheers |
Posted: Mon Mar 29, 2010 10:48 pm Post subject: |
That doesn't surprise me at all, the battery seems to get used at a very high rate with that Navcore installed, leave it connected to a charger 24/7 - Mike |
