Pocket GPS World :: View topic - help to install navcore 9
PostPosted: Tue Mar 23, 2010 3:24 pm    Post subject: Reply with quote
The SEARCH button above is your friend..... Cool
Try THIS TOPIC for starters.
AndyVaughan
PostPosted: Tue Mar 23, 2010 5:58 pm    Post subject: Reply with quote
I agree with everyones comments about Navcore9 - don't use it on a device it hasn't been released for - hang fire and wait.
TT appear to be in a transitional period in regards to the Linux kernel - the x50 range use a different kerne hence why standby and LIVE don't work properly on older devices.
blackstars
PostPosted: Tue Mar 23, 2010 8:23 pm    Post subject: Reply with quote
mikealder wrote:
A 940 loaded with the Fiat Blue Me Navcore 9 is what you want as this does offer different routes depending upon vehicle type using the standard map, have a look at This
I would suggest you get a 4GB MicroSD card for the software to go on along with a map, once you have got the memory card we can point you in the direction of installing it - Mike
yeah, ive seen this video, thats exactly what i am after, i have already got a 8gb micro card for my unit, how do i go about installing it onto my micro card ? cheers
PostPosted: Tue Mar 23, 2010 8:36 pm    Post subject: Reply with quote
Did you look at the link I found for you above?
The download location and some instructions are in the last two posts on page one.
blackstars
PostPosted: Tue Mar 23, 2010 11:28 pm    Post subject: Reply with quote
thanks for the advice, installed fiat blue me, onto mem card, everything seems to be fine, only prob is, mp3 player not working, lost all my favs and i cannot seem to be able to get rid of the green phone symbol on the left hand side of the screen
PostPosted: Wed Mar 24, 2010 12:15 am    Post subject: Reply with quote
If its a 940 running the Blue Me software then the mp3 player should work fine (mine does/ did, as you have seen).
As for the silly icon on the left side of the screen go to change preferences/ quick menu preferences and deselect whatever stupid option TomTom have enabled on the device (probably something to do with the phone) - Mike
MrT
PostPosted: Wed Mar 24, 2010 12:29 am    Post subject: Reply with quote
The only way to get rid of the handsfree green icon using Nav9 on an x40 is either to delete the pairing with the mobile as it will not permanently deselect from the quick menu or to add another item which gives you a different icon to the shortcut menu which is equally annoying.
Drivelux
blackstars
PostPosted: Wed Mar 24, 2010 12:39 am    Post subject: Reply with quote
got rid of phone icon, still no mp3 player though....
AndyVaughan
PostPosted: Wed Mar 24, 2010 9:16 am    Post subject: Reply with quote
Do you have a mp3d file in the bin folder on the device?
If not, copy one from another Navcore release in to that folder.
blackstars
PostPosted: Wed Mar 24, 2010 4:08 pm    Post subject: Reply with quote
no it did'nt, so copied as you said, working fine now, thank you very much mate.
i do have one very quick question, i hope you could help me with concearning the maps, now i can change the vechicle profiles on the device to truck mode, will the currant maps know where all the low bridges, weight limits are ? or will i need the truck maps ? cheers
PostPosted: Wed Mar 24, 2010 6:22 pm    Post subject: Reply with quote
The route is certainly different when using the different vehicle profiles but whether it will avoid low bridges etc I have no idea, for that to work I would expect you to need the Truck maps - Mike
blackstars
PostPosted: Thu Mar 25, 2010 9:19 pm    Post subject: Reply with quote
had a playaround with the routings whilst in truck mode, and its sending me down roads where the bridge is too low for the truck, so the tt maps does not know where all the bridges are. ive seen somewhere on this site where you can download a low bridges program, if i was to do this, would the tt maps then know where all the low bridges are ? cheers
PostPosted: Thu Mar 25, 2010 9:56 pm    Post subject: Reply with quote
You would get a warning from the device for a low bridge POI file as you approach it (if configured for warning against this POI file) but the device has no way to avoid POI so it won't prevent it routing you under such a hazzard - Mike
blackstars
PostPosted: Mon Mar 29, 2010 10:32 pm    Post subject: Reply with quote
since installing fiat blue me, unit has a flat battery, every time i try to switch it on, anybody got any ideas on this one ??? cheers
PostPosted: Mon Mar 29, 2010 10:48 pm    Post subject: Reply with quote
That doesn't surprise me at all, the battery seems to get used at a very high rate with that Navcore installed, leave it connected to a charger 24/7 - Mike
Page 2 of 3
