Pocket GPS World :: View topic - BT's broadband-boosting iPlate
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area
john877
PostPosted: Fri Jul 04, 2008 8:18 am    Post subject: BT's broadband-boosting iPlate Reply with quote
http://www.pcpro.co.uk/news/209976/bts-broadbandboosting-iplate-goes-on-sale.html
PaulB2005
PostPosted: Fri Jul 04, 2008 8:30 am    Post subject: Reply with quote
Hmmm. Not so much a "Booster" as such. It just removes the interference on the line which usually decreases the users speed.
A bit like claiming i can "Boost" the speed of your car for £20 and then just removing all the crap from your boot.
Good idea, but not sure it should be called a "Booster"....
gardenshed
PostPosted: Fri Jul 04, 2008 11:42 pm    Post subject: Reply with quote
actually it sounds more like an admission of guilt by BT that they cannot correctly filter the telephone lines, but it's ok, joe public, SUCKER numero uno can pay 17 quid to get around the issue and BT are doin them a favour Rolling Eyes
WLMOATE
PostPosted: Mon Aug 18, 2008 7:23 pm    Post subject: Reply with quote
The line is fine , the issue is created by having a third ring wire which is created in the master socket and run around a house. If ringing was created on a balanced pair this would be better.
However if you want to have the same result without spending money, reove the wire from pin 3 on the IDC connector in the rear of the face plate at the master socket.
If you have argos style extentions fitted these can be quite poor due to the limited number of twists on the cable
Wayne
MY-SOS, Benefon TWIG, DriveSmart, Wayfinder
gardenshed
PostPosted: Mon Aug 18, 2008 11:21 pm    Post subject: Reply with quote
sure iäve got four cables connected at mine, further investigation is obviouslz required, thanks for that, anz downfalls to this solution?
WLMOATE
PostPosted: Tue Aug 19, 2008 6:54 pm    Post subject: Reply with quote
Here goes a bit of a lesson for you.
BT supply the telephone service to your house on 2 wires, the ring signal is imposed on the DC current. A standard master socket has a capaicator connected from one of the paiir of incoming cables this is used to seperate the ring signal onto wire 3 .
The incoming wires are reffered to A and B
Old style telephones do not have a ring capaicator fitted hence the need for the 3rd wire.
Modern telephones have them fitted so 99% of installations only require 2 and 5 So removing wire 3 would cause the loss of ringing in old telephones
Wire 4 is NOT needed
Common faults in house wiring is caused by poor connections by not using an IDC ( Insulation Displacment Connector) tool to fit the wire. Poor quality diy wire in cheap phone ext kits
So in your case remove 3 and 4 if needed. Though this may not increase ADSL speeds
PS Dont use text speak
Wayne
Border_Collie
PostPosted: Tue Aug 19, 2008 9:00 pm    Post subject: Reply with quote
The Default TCP Window size is for Dial-up. For BB you need to carry out the following:-
Ref: PCPitstop.
Only attempt it if you feel competent working within the Registry.
Get it wrong, or change any other settings, and your computer may stop working.
The change recommended below will usually increase performance for broadband users that have the default Windows settings.
To change your TCP Receive Window size:
Launch window registry editor by clicking on Start | Run .
Click in the Open dropdown box and type in regedit.exe then click OK .
Back up your registry by selecting File | Export type in a meaningful file name, in the export range section select All and save to your hard drive. To restore your old registry you simply import this file.
Next you need to create a new registry key. On the left side you need to go to the directory HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
Select Edit | New | DWORD Value .
Rename the new registry key to TcpWindowSize.
Modify the registry setting for TcpWindowSize by double clicking on the key.
Change the Base Setting to Decimal.
Enter the value 64240 and click OK, then exit RegEdit.
For these settings to take effect you need to close all your open applications and reboot your system.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area All times are GMT + 1 Hour
23.044 (23 Apr 25)
