Pocket GPS World :: View topic - Tom Tom One - Can't find Map on new SD card
James17
PostPosted: Wed Feb 14, 2007 11:04 pm    Post subject: Tom Tom One - Can't find Map on new SD card Reply with quote
I created a back up of all the files on my TT one, which are stored on my laptop. I then transferred these onto a larger SD card so I could get all my POI's set up. The transfer went ok, however when I installed the new SD card into my TT it went through the normal start up process and then asked for me to choose a map, however it didn't list any?
I'm a little puzzled as I originally copied all the files that are on the SD card I got with the TT, so how can it not find the map?
The SD card was in my ipaq when I transferred the files could this of effected it? Should the SD card have been in my TT?
Any ideas?
PostPosted: Thu Feb 15, 2007 8:33 am    Post subject: Reply with quote
Check to see if the Map Folder is in the Backup, and make sure the size on it is similar to the one on the original Card..
James17
PostPosted: Thu Feb 15, 2007 9:10 am    Post subject: Reply with quote
Which file should I be looking for on the TT one?
Thanks for your help.
PostPosted: Thu Feb 15, 2007 12:28 pm    Post subject: Reply with quote
It's a FOLDER (containing files).
Depending on whether you have the Europe or Regional version of the One, the map folder will be called a different name.
Possible names are "Great_Britain-Map" "Western Europe" "UK and IE Map" or similar. Whatever it is, the name should make it obvious.
Look inside the folder and you will see a whole load of files (including any POIs you've added). The largest vital ones are called cline.dat, cname.dat, cnode.dat and faces.dat - these ARE the map (although all the smaller files are essential too!).
If you haven't got that folder, or it's missing those files, it looks like your original backup didn't work properly. Was it done via "Home" by any chance?
James17
PostPosted: Thu Feb 15, 2007 1:40 pm    Post subject: Reply with quote
I've checked all the files in the UK and Rep. of Ireland folder and they are all there!
Its still asking me which map I want to install and there are none listed?
Any ideas?
PostPosted: Thu Feb 15, 2007 2:03 pm    Post subject: Reply with quote
Yes, I'd suggest your next step is to download this little utility, DriveZ
This will enable you to make a list of all the files inside your map folder, which you can then paste here, so we can have a look. Saves a lot of time and guesswork.
Make sure you have UNticked the "Remove extensions" box before you click the big button to make the list in the right-hand window.
Post your resultsup here and hopefully all will be revealed...
James17
PostPosted: Thu Feb 15, 2007 6:24 pm    Post subject: Reply with quote
Got it working I think the SD Card was corrupt so I reformatted it and its working a treat now!
Thanks for all your help.
