Pocket GPS World :: View topic - 3.1 Install problems
ctp
PostPosted: Thu Mar 23, 2006 11:32 pm    Post subject: 3.1 Install problems Reply with quote
Hello all,
Today I bought an HP1710 with the via michelin 3.1 satnav bundle.
Worked great out the box on the way home from work but...
I'm having terrible difficulty installing the software onto the PC.
Whichever way I try, I get the following message;
"Cannot copy the file :C\Pro........ \ MapSonic.exe"
I've not typed in the full path by the way.
I've tried every workround I know, followed the instruction to the letter and searched for patches or downloads.
Anyone else had similar problems ? I've also searched on here and not found any reports.
Looks like I may have a faulty cd-rom ?
Any help or advise much appreciated.
elan2s
PostPosted: Fri Mar 24, 2006 12:34 pm    Post subject: Reply with quote
Have you turned off any firewall or anti-virus software? One or other may be being over zealous in stopping you writing a .exe file to disk. Other than that I can't think what the problem may be.
tanda
PostPosted: Fri Mar 24, 2006 5:30 pm    Post subject: Reply with quote
Hi ctp, I had the same problem, installed ViaMitchelin from the SD card, then It wouldn't let me install what was on the CD, onto my PC. There is a Bug in the softwear, that stops you installing the CD if you have installed ViaMitchelin from the SD card first, But there is a patch, on their website to correct this, I downloaded the patch, and It cured the problem and I now have the CD installed on the PC. I tried looking for the patch, but can't find it, but there is an upgrade from ViaMitchelin 3.1 to 3.2, which INCLUDES the patch, try downloading that, if it's no good I have the original patch on my PC, I could e-mail it to you.
Audi A3 Sline sat nav
tanda
PostPosted: Fri Mar 24, 2006 5:32 pm    Post subject: Reply with quote
oh pooo, Laughing Out Loud, forgot to give you the link
http://www.viamichelin.co.uk/viamichelin/gbr/tpl/psg/produits/htm/pda_patchs.htm
ctp
PostPosted: Sun Mar 26, 2006 9:19 pm    Post subject: Reply with quote
Thanks for the replies....
I sorted this by doing a hard re-set (wiping clean the PDA) and installing from there.
The patch you talk about, I tried that and it only works if your already installed !!
Many thanks again for the advise.
alfaowner1
PostPosted: Sun Sep 03, 2006 1:56 am    Post subject: Reply with quote
Lads, I hope this will help someone as it solves the problem.
visit: http://www.viamichelin.co.uk/viamichelin/gbr/tpl/psg/produits/htm/pda_patchs.htm
Download and Install the MapSonic Patch 1.3.2 for Pocket PC, and then install your CD Smile
Works a treat
Ian
http://www.alfaowner.com/Forum
tanda
PostPosted: Sun Sep 03, 2006 12:07 pm    Post subject: Reply with quote
Hi Alfaowner1, The patch you mentioned is for Palm users using VM 1.1 or 1.2. Ctp is using Windows 2003, with VM 3.1, the patch you mentioned won't work, he has to use the other patch I quoted, but it doesn't matter, as he did a hard re-set and started again. ok if you have just bought it, and haven't got anything on your PDA yet, but if you dont want to re-set everything, you need to use the patches we quoted, depending on the type of PDA.
alfaowner1
PostPosted: Mon Sep 04, 2006 1:22 am    Post subject: Reply with quote
You cannot use the patch you keep mentioned as v3.1 has to be installed to patch it in the first place.
Re: the link, I was a bit tired, anyhow, this is the lin kti map sonic.exe... install that and then install your disk, and it works.
http://www.viamichelin.co.uk/viamichelin/gbr/jsp/nav/patch_V1-3-2-ppc.jsp
I did it last night. I think th eproblem is that the disk is asking to install map sonic from the via file on the PC and not from the disk. Definatley an error by VIA when making disks. Laughing Out Loud hahaha
AO
