Pocket GPS World :: View topic - poi handler .com
poi handler .com
mazelda
PostPosted: Wed Mar 30, 2005 11:04 pm    Post subject: poi handler .com Reply with quote
could anybody tell me how I could get rid of many of the shortcuts to the poi's from this website
I downloaded and installed poi warner and set it up on my transonic 3002 and then registered it also set it up for the poihandler.com website it then proceeded to load all its shortcuts for all the poi's around europe most of which i'll never use is there any way I can remove them, also how can I delete poi's that I no longer want (set some up by accident) can't seem to find how to do it through poi warner.
I tried to use activesync and just delete the files but it did not work.
PostPosted: Fri Apr 01, 2005 7:01 am    Post subject: Reply with quote
You need to delete the groups within POI-Warner itself.
Select Poi Manager / Poi Manager. You will have an edit screen and at the top is a drop down list of all the poi's that are downloaded.
Select one to delete, and the contents are displayed in the edit screen. On the File Menu (at the bottom) select Delete All.
This will remove all the entries in that category, and because Warner knows it's empty will remove the category the next time you connect on-line.
Repeat as necessary.
mazelda
PostPosted: Fri Apr 01, 2005 12:25 pm    Post subject: Reply with quote
many thanks will give it a try
22.055 (29 May 24)
