Pocket GPS World :: View topic - Even Dave get’s it wrong!
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Even Dave get’s it wrong! Reply with quote
Well I must say even we (okay I) get foiled from time to time!
Had to take a drive on Saturday, received a fix on the Socket BTGPS I'm testing, and low and behold, 3 mins later, lost the fix, TTN2 seemed to hang, no data being received.
Found out about 10 mins later after soft resetting the iPAQ, much to my surprise, that I had forgot to charge the BTGPS, and the battery had run flat! Didn't have any in-car chargers either with me (only the 38xx series chargers) Luckily I managed to fall back to a Leadtek 9531, as this was a journey I didn't actually know where it was!
I'm surprised someone hasn't posted a story like this already! Needless to say my charger cables going with me in the car from now on!
alienrider
I had the same thing happen to me ! The BT GPS doesn't seem to give any kind of warning when the battery is running low on juice !!! Or have I not read the scant manual closely enough ? :-)
B
A difficult problem can be solved more easily by reducing it to the question, "How would Bagpuss handle this?" ;-)
Setup: Garmin 3950LMT + PGPSW CAMS
I have had this experience as well. Having driven from home to Heathrow I forgot to turn the Emtac off whilst in the airport. After 1.5 hours driving, 2.5 hours in the airport, and 2.5 hours flying the battery had expired. I went to switch it on in foriegn parts and the unit wouldnt issue a squeak.
Good thing I had a Garmin Geko with me. Only had a single charger there so had to take turns PDA and Emtac charging. Could have done with the new PC-Mobile cable there.
Just had a thought, need to check the voltage, but how about the battery extender ?
ArthurFuxake
I use an IPAQ car charger (spare now that my IPAQ has a powered brodit mount) that I have 'hardwired' in to the car to charge/power my BTGPS, so I now always have the thing plugged it the whole time it's in the car. That way it's never flat and always ready for other uses outside the car (such as geocaching...)
Steve
FishSlice
quick question, and it maybe stupid, but I'll ask anyway....
Which iPaq charger cable is compatible with the emtac ? I assume its the charger without the iPaq wide connector on the end, ie, just the round one ?
Si
-----<br>
Cheers<br>
Si
Cessquill
Another one - once the BT GPS is fully charged, what sort of drain does it take if plugged in. That is, if I wired it to a permanent supply (ie, not on the switched ignition), would it be safe to leave on charge in the car all the time, so it's always fully charged and ready to be taken out of the car when necessary?
What's going on? Where am I?
Power drain from a car battery perspective, virtually nothing, shouldn't be an issue. However, there have been comments about leaving the BT GPS on permanent charge, as the BT GPS from what I've read, doesn't seem to like it.
22.051 (01 May 24)
