Pocket GPS World :: View topic - POI 3.5 & Destinator
stoneman
PostPosted: Fri Mar 04, 2005 9:08 pm    Post subject: POI 3.5 & Destinator Reply with quote
With the new poi 3.5 now avaliable with support for Destinator
Can anyone explain how to use the safety camera database with POI & how to get it on the pocket pc using the Destinator console.
Many thanks
System: XDA II
Tom tom BT gps
Destinator 3
GPSinC3
PostPosted: Sun Mar 06, 2005 10:54 pm    Post subject: Reply with quote
Ive been p[aying and it seems like, download file using POI and save to LOCAL as csv file. Then load console, select a map, doesn't seem to matter which one and the import favourites menu item is available. Open that by browse to directory where you saved it and select, click <convert> and then <download>, if you have PDA connected it saves it in favourites
Change the name of the file to auto alert 1 or change the name before the above when its on the PC
There will be an auto alert 1 dat file on PDA in common/favourites. Select this on PDA and tools/edit allows setting distance
I found it slows down the loading of D3
stoneman
PostPosted: Mon Mar 07, 2005 8:03 pm    Post subject: Reply with quote
Thanks i'll give it a try.
Stoneman
22.055 (29 May 24)
