Pocket GPS World :: View topic - AA Battery carrier?
AA Battery carrier?
mupp
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: AA Battery carrier? Reply with quote
Has anyone found a good, small, waterproof durable container that would hold two AA Batteries as a backup for my hiking gps?
Best I've found is a double AA clip from a model shop, but it leaves them open to moisture and has external contacts. Anyone found a better container or pouch, just something I can slip into my pocket?
Try looking at the Otterbox 1000 reviewed here http://www.pocketgpsworld.com/otterboxes.asp it may be a bit OTT for your requirements, but will certainly keep your batteries safe and dry.
Pc-Mobile
Can you not just keep them in your pocket?
Or use a little polythene bag that you can "press and seal".
Pc-Mobile
http://pc-mobile.net/gps.htm
mduncombe
I just wrap mine up in a bit of insulation tape or duct tape.
Mark
Biv
PostPosted: Fri Jan 09, 2004 4:57 am    Post subject: Good Cheap case Reply with quote
I made one out of plastic pipe. Get the size you need and cut it to length and put solid caps on it. They usually fit pretty tight. You can glue one end if you want. Thumbs Up
musika
PostPosted: Sat Jan 10, 2004 10:15 pm    Post subject: Reply with quote
Try here. Haven't checked it out.
It may be U.S. only, but it's a start.
http://tinyurl.com/2277m
m.
dlegros
PostPosted: Tue Aug 03, 2004 4:22 pm    Post subject: Reply with quote
www.7dayshop.com carry a variety of battery and memory card cases:
http://www.7dayshop.com/catalog/default.php?cPath=777_5_503&sort=2a&filter_id=108
I have a couple of the AA cases (hold 8 AA cells) and the combicase (holds 4 AA cells and a memory card)
Dom
musika
PostPosted: Tue Aug 03, 2004 6:11 pm    Post subject: Reply with quote
7dayshop have got these. I have just bought half a dozen. At 79p each, I don't think they can be beaten.
http://www.7dayshop.com/catalog/product_info.php?cPath=&products_id=98970
(Watch the line wrap.)
Cheers,<br>
Ray.
UKHABU
PostPosted: Mon Nov 01, 2004 5:04 pm    Post subject: Reply with quote
Maplins have any number of different battery holders for about 49p!!
