Pocket GPS World :: View topic - Map datum
Map datum
Bluestar2005
PostPosted: Thu Feb 24, 2005 8:26 am    Post subject: Map datum Reply with quote
I don't fully understand the manual re map datum.
I have my eTrex Legend set to Ordnance Survey GB at the present.
I intend to travel in Holland, and have installed maps and waypoints from the European Roads & rec disk.
Do I need to alter the datum settings for the GPS to work properly in Holland? If so what settings should I use?
Privateer
PostPosted: Thu Feb 24, 2005 11:16 am    Post subject: Reply with quote
Hi Bluestar2005,
If you look at any decent map (and the Ordnance Survey maps are some of the best) then you should see the Datum that should be used with the map. Sometimes you even get the position format as well. E.g.:
Britain
Map Datum: ORD SRVY GB
Pos Format: British Grid
Jersey (Channel Islands)
Map Datum: European 1950
Pos Format: UTM Grid Zone 30
If the map doesn’t specify a Datum then you can try WGS84. WGS84 should also be used when using a hand held GPS unit with a computer running SatNav applications as most SatNav applications use WGS84 for their electronic map data.
Robert.
Garmin Camper 770 LMT-D
Bluestar2005
PostPosted: Thu Feb 24, 2005 7:31 pm    Post subject: Reply with quote
thanks for that - another reason to look forwardto the trip - can't wait to try it our abroad!
