gps_master Occasional Visitor
Posted: Wed Feb 16, 2005 10:22 pm Post subject: TomTom Bluetooth GPS with Oziexplorer, MDA II with ROM 1.72 |
Hello,
I have a T-Mobile MDAII with updated ROM from 1.60 to 1.72.
After that upgrade a run of TOMTOM Nav 3 AND Oziexplorer (of course not at the same time) is no longer possible. (TT--> run, OZI --> no run)
I was asked, to deinstall the well running TomTom and try if Oziexplorer is running without TT. Result: Negative. (Is the deinstallation of TomTom really complete, or does remain some thing on the MDA?)
One interesting thing I have noticed after the Update of the ROM:
The previous setting of OZI were: COM 5, 38400, GPGLL
With this setting Ozi with ROM 1.60 on MDA II work fine.
After update to ROM 1.72 OZI shows at once a "ERR" in the right upper corner (instead of an "ON" when OZI worked normal)
So I think, the friendly collegues of T-Mobile have again mixed up something on the Bluetooth input channels setting.
--> This is real hard, meanwhile i love cables and hate BT.
Has some body an idea what t-mobile has done in the update of the ROM 1.72? Do I really have to go back to 1.60 (nooooooooo!!!)
How can i config the Bluetooth settings myself (helptools....)?
Please help me. Thanks, Stefan
PS: I think, I have to give up my nick name |
lbendlin Pocket GPS Staff
Posted: Wed Feb 16, 2005 10:36 pm Post subject: |
In the Bluetooth Settings, can you find the outgoing Serial Port? it may have changed... _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Feb 17, 2005 10:26 pm Post subject: |
Hello,
There are not a lot settings on the MDAII you can select:
This picture is similar to the previous ROM1.60. I found no other way to change setting on PPC2003.
By the way: Enclosed you find the picture of OZIexplorer, showing the "ERR" symbol since ROM1.72, which was "ON" using ROM1.60.
Maybe somebody can help me. Thanks, Stefan[/img] |
Posted: Thu Feb 17, 2005 10:46 pm Post subject: |
Enclosed the possible selection of port in OZIexplorer:
Stefan |
Posted: Fri Feb 18, 2005 2:35 am Post subject: |
Stefan,
you need to check the box next to "Auslaufender COM Port" (was für eine dämliche Übersetzung)
After that do a soft reset and try again _________________ Lutz
Posted: Fri Feb 18, 2005 8:10 pm Post subject: |
Hello Lutz,
Thanks for the quick response.
Result: Negative.... ERR occur again at once after trying to establish the Blutooth link to the TT GPS (also with TomTom N3 uninstalled and "auslaufender Port enabled" ).
???, Stefan |
Posted: Sat Mar 12, 2005 6:31 pm Post subject: New ideas ??? |
Hi Lutz,
Are there some new ideas to my still existing problem from your side???
I still did not reinstall the older ROM 1.60 (instead of the 1.72) on my MDA II, because of the big afford.
...hopefully a door opens somewhere and I will come in the Bluetooth heaven, meaning, that TT Nav3 and Oziexplorer is running...
Are the diagnosis/configuration tools for PDAs, which show the config of the BT ports and let them change?
Thanks for your assistance, Stefan |
alix776 Pocket GPS Moderator
Posted: Sat Mar 12, 2005 6:33 pm Post subject: |
to get this combination to work you need to install pocket bluetooth tools on the the pda then install gps 2.06 otherwise youll not get them to rum on the mda _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
