Pocket GPS World :: View topic - Newbie needs help finding a power cable
Colin009
PostPosted: Wed Feb 16, 2005 11:42 pm    Post subject: Newbie needs help finding a power cable Reply with quote
Hi All.
I've just broke the power cable for my TomTom3 car kit, it has a blue lable with 4A00.003 on it. have had a look for this and no luck, thought I'd ask the experts
Pocketgps
PostPosted: Thu Feb 17, 2005 1:10 am    Post subject: Reply with quote
Hello Colin009,
Try e-mailing or ringing some of the companies that are around this forum screen, most of them sell replacement parts, i am sure that they can help you.
oddsock
PostPosted: Thu Feb 17, 2005 9:33 am    Post subject: Re: Newbie needs help finding a power cable Reply with quote
Colin009 wrote:
Hi All.
This is also the part no of the power lead for the ttgo what about trying TomTom repair!! Which part have you broken? is a repair or modification possible .When looking for a replacment you need to check how far the cigar plug protrudes out from the dash as on my car the gear stick hits on anything other than the latest lead but may not be an issue on yours.
Colin009
PostPosted: Thu Feb 17, 2005 4:45 pm    Post subject: Reply with quote
Thanks for replys guys.
jonno1965
PostPosted: Sat Feb 19, 2005 10:49 pm    Post subject: Reply with quote
Hi - I have exactly same cable for TTN Part No. 4A00.003
After only two months use - it failed - luckily I had arrived at my destination.
Don't buy another cable - I Have fixed mine.
Undo the philips screw in the cigar lighter connector and also unscrew the tip of this connector using a pair of pliers.
lever off the chrome ring around the tip and you will now be able to open the lighter connector assembly - CAREFUL!!! - a small hex nut will fall out.
Inside is a fuse - mine was intact - BUT the +12V (Red Wire) had become detached from the fuse spring.
A severe lack of solder here!!!! - I resoldered using plenty a re-assembled - a bit fiddly - but hey presto it all works fine.
Saved me £17.00 or so!!!
Regards
John Laughing
