Pocket GPS World :: View topic - Losr USB connection
Losr USB connection
zappy61
PostPosted: Sun Feb 06, 2005 7:20 am    Post subject: Losr USB connection Reply with quote
Can anyone help. I have used USB connection for my cradle and 3970 for 18 months. Suddenly I lose the connection. I have tried soft reset, configuring the connection settngs to usb and checked the cable but to no avail. However, I can connect using COM1 which I can't work out am I missing something in the settings?
Graham
PostPosted: Mon Feb 07, 2005 5:30 am    Post subject: Reply with quote
USB connection to where ? to the PC ? or do you have a USB GPS receiver? In that case, do you have a serial to USB converter cable?
zappy61
PostPosted: Mon Feb 07, 2005 8:50 am    Post subject: lost usb connection Reply with quote
I have lost the usb connection to the pc from the cradle. I can connect via com1 but not usb, it has been fine for 18 months. Ichecked the cable its ok and also the settings in activesync connections on the pda. Any suggestions?
Graham
PostPosted: Mon Feb 07, 2005 2:53 pm    Post subject: Reply with quote
I had something similiar after I toyed with Check_Notifications and managed to delete the "wakeup on connection" notification for repllog.exe
Plug in the USB cable, set ActiveSync to USB and then run \windows\repllog.exe on the PocketPC - see if that helps.
zappy61
PostPosted: Mon Feb 07, 2005 9:39 pm    Post subject: lost usb connection Reply with quote
Sorry Lutz can you explain how I start repllog.exe on the pda?
Graham
PostPosted: Mon Feb 07, 2005 10:44 pm    Post subject: Reply with quote
use the file explorer, navigate to \windows, tap on repllog
zappy61
PostPosted: Tue Feb 08, 2005 9:26 am    Post subject: Reply with quote
Sorry Lutz but I don't seem to have that file, could it be deleted?
Graham
PostPosted: Tue Feb 08, 2005 3:02 pm    Post subject: Reply with quote
That would be pretty bad. In this case only a hard reset will help to restore the link (the file itself is in ROM)
Backup the whole Pocket PC, do a hard reset, confirm USB is working, and do a complete restore.
zappy61
PostPosted: Wed Feb 09, 2005 11:42 pm    Post subject: lost usb connection Reply with quote
Thanks,
I ran the file by using the open path command in windows file explorer. It said 'usb connecting to host' but it still won't connect. Any other suggestions please?
Graham
PostPosted: Thu Feb 10, 2005 12:02 am    Post subject: Reply with quote
Reinstall ActiveSync on the host
zappy61
PostPosted: Thu Feb 10, 2005 11:27 am    Post subject: lost usb Reply with quote
Tried reinstalling activesync with all latest updates to 3.8, made sure pda is set to usb, even turned off firewall, no joy. Still keeps saying verify the connection and if I go next does the same again. I can't get com ports now so I am really stuck. Any more suggestions?
Graham
PostPosted: Thu Feb 10, 2005 3:32 pm    Post subject: Reply with quote
no, apart from a hard reset there are no more suggestions.
