Pocket GPS World :: View topic - swith from sirf to nmea on gr230
donster22
PostPosted: Wed Feb 02, 2005 10:26 pm    Post subject: swith from sirf to nmea on gr230 Reply with quote
hi
can't find the answer to this....
i read that sirf is faster to update and more accurate. is this correct?
if so, how on earth do i switch my gr230 onto sirf? and also, how do i turn on power saving mode?
if i switch to sirf, which baud rate should i use and will it definitely be better?
cheers
donster22
donster22
PostPosted: Thu Feb 03, 2005 11:23 pm    Post subject: Reply with quote
found it with winfast navigator
PostPosted: Sat Feb 05, 2005 11:36 am    Post subject: Reply with quote
Be careful when switching, if you switch from NMEA to SIRF make sure you switch to the same baud rate before trying to change the baud rate otherwise you'll de-sync the BT module.
22.053 (15 May 24)
