Pocket GPS World :: View topic - XDA II & Navman 4420 GPS bluetooth problem
markqbase
PostPosted: Sat Jan 22, 2005 5:20 pm    Post subject: XDA II & Navman 4420 GPS bluetooth problem Reply with quote
I have just bought a Navman 4420 for pocket PC. I am running ROM version 1.72.00WWE, radio version 1.17.00 on an XDA II. I think I can bond the XDA with my GPS ONE receiver, (it has accepted NAVMAN passkey, once I installed the patch) but I am not clear on how to set up the COM port. The bluetooth light on the GPS continues to double flash, suggesting it has not bonded. please help!!
alix776
PostPosted: Sat Jan 22, 2005 5:36 pm    Post subject: Reply with quote
youll need to set the com port as com 5 in not sure of the baud rate try 3400
device Lumia 950 xl
markqbase
PostPosted: Sat Jan 22, 2005 5:46 pm    Post subject: Reply with quote
how do i set the port though? instructions say to use the GPS Status screen on PDA, bur software won't let me as it brings up the "waiting for gps" message, and no menus!
alix776
PostPosted: Sat Jan 22, 2005 5:56 pm    Post subject: Reply with quote
im not familiar with the navman sofctware though if you hang on a while one of the others should be able to help
device Lumia 950 xl
markqbase
PostPosted: Sat Jan 22, 2005 6:45 pm    Post subject: problem solved Reply with quote
The instruction manual is wrong - it states that the BT will flash once to show it's paired, then go on to set up the COM port on the app & do a GPS fix. It actually double flashes, then set up the port and it single flashes, then do a fix! Confused? I have been all day!
alix776
PostPosted: Sat Jan 22, 2005 8:10 pm    Post subject: Reply with quote
as its a new reciver try leaveing it on with a clear veiw of the sky say in the car or on a window sill (thought doubleglazing is heatreflective glass)
for around 30-45 minutes switch on then try and pair it again when pairing it you will be asked if you want to create a serial port at this point select yes. ifyou still have no look then download pocket bluetooth tools from the link and try the process againhttp://www.bluetooth.jazztel.es/
device Lumia 950 xl
markqbase
PostPosted: Sun Jan 23, 2005 6:41 pm    Post subject: Reply with quote
thanks for your help! all worked fine once I sussed that the instructions were in the wrong order!
22.053 (15 May 24)
