Pocket GPS World :: View topic - Avoid Road doesn't light up...
mtrimmer
PostPosted: Sun Jan 16, 2005 4:23 pm    Post subject: Avoid Road doesn't light up... Reply with quote
I'm new to CoPilot, and I've spent the better part of this week learning how to operate this package. However, I can't seem to make the Avoid Road function work. I built an itinerary between two points, got the directions, and it takes me through no man's land. I have tried to select a road and click the "Avoid Road" button to come up with a new route - no dice. I have tried it in both Guidance and Planning modes with the GPS on or off with no luck. Suggestions? Thanks!
iPAQ 4155 (1.10 ENG)
ActiveSync 3.8 build 5004
Treo 600 - Verizon (CDMA)
i.Trek Bluetooth GPS Receiver (Nemerix 16 channel chipset)
GPS Softwares - CoPilot / Mapopolis
PostPosted: Sun Jan 16, 2005 4:48 pm    Post subject: Reply with quote
These functions do only work in guidance mode.
lynnk
PostPosted: Tue Jan 18, 2005 4:43 pm    Post subject: Reply with quote
I'm not sure how you are using the Avoid function. As Lutz said, it only works when you are in the Guidance mode. Here's how I use it and it works:
1. Plan you trip ... select you destination.
2. Select Guidance and let Copilot calculate the route.
3. As you start driving, select Itinerary and you should see a list of you upcoming turns.
4. Before you get to a particular turn, tap that line and then tap Avoid. At that time, you should see Copilot recalculate your route and display a new route. You can confirm by going back into the itinerary and you should see some other route listed.
22.052 (08 May 24)
