Pocket GPS World :: View topic - double poi messages
double poi messages
Goto page Previous  1, 2, 3, 4  Next
aliendad
PostPosted: Sun Nov 07, 2004 11:55 am    Post subject: Reply with quote
so in that case, make the bmp files smaller may allow them to be viewed.
and thanks for the info
jamesanthony
PostPosted: Sun Nov 07, 2004 12:06 pm    Post subject: Double POI messages Reply with quote
I`ve tried turning off the POI view on screen and it made no difference, still getting double helpings, has anyone else had any luck.
Regards
Jim.
Enigma644
PostPosted: Wed Nov 10, 2004 12:46 pm    Post subject: Stutter fixed on my 6600 Reply with quote
I used POI edit to cut down the number of POI's. I live in Surrey, so I removed everything north of colchester (52 deg) and Everything west of Portsmouth (-1.75 deg).
I now have:
Gatso - 1106 cams
Mobile - 392 cams
RedLight - 131 cams
Specs - 0
I still get an ocasional stutter, but it's barely noticable.
Has anyone worked out the upper limit on POI's? Do the built in POI's make a difference? I tried turning off the Petrol Stations, which are on by default, but didn't notice a difference.
eddie2k2
PostPosted: Fri Nov 12, 2004 9:49 am    Post subject: Reply with quote
try this trick
use dumpov2.exe from TT website to convert original ov2 file to .ASC file then use makeov2.exe to convert it to .ov2 .
works better (90%).
aliendad
PostPosted: Sun Nov 14, 2004 5:40 pm    Post subject: Reply with quote
followed the dump & make suggestion, and it certainly looks like it works
thanks very much.
eddie2k2
PostPosted: Sun Nov 14, 2004 8:11 pm    Post subject: Reply with quote
glad to hear that. :D
JConnors
PostPosted: Tue Nov 16, 2004 5:58 pm    Post subject: TomTom Support e-mail... Reply with quote
I wrote to the TomTom support team and this is their responce:
Subject
*** See http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&...
Discussion Thread
Response 16/11/2004 02.12 PM
Dear Mr Connors,
This will happen if many POI databases has been installed.
What we would advise you to only use ONE ov2 file at the time and this should solve your problem.
Due the limited processing power on a 6600 it could happen that TT mobile is not able to handle proximity monitoring for multiple POI files.
solution : reducing the number of monitoring multiple POI files should fixed problem.
A other thing that could cause the this problem are corrupting POI's .
Solution: Remove the all POI and re add again.
We hope to have answered your question to your satisfaction.
With best regards,
The TomTom Customer Support Team
Dosn't say much more than what everone else here has been saying.
Jamie
JConnors
PostPosted: Tue Nov 16, 2004 6:10 pm    Post subject: TTM POI - Gatdo cameras Reply with quote
Has anyone got a POI file with just th Gatso cameras in England? Or is there a way of displaying the cameras in the ov2 file on a map and removing the non required POI and saving the file as an ov2?
Smartboy
PostPosted: Tue Nov 16, 2004 6:15 pm    Post subject: Reply with quote
I also did the dump and make, i did the same to the Specs ov2
and the Mobile ov2 as well and i don't get any stuttering at all now.
Thank YOU eddie for that i am very pleased now.
I wonder why do you think it works?, the file size is a little larger or
could it be that it is the proper tomtom format?.
Thanks again.
Res
PostPosted: Thu Nov 18, 2004 12:20 pm    Post subject: Reply with quote
Yes seems to work for me now, only the occasional stutter. Would the pocketGPS team consider releasing future updates to the database in this format please?
flasher
PostPosted: Thu Nov 18, 2004 11:21 pm    Post subject: Reply with quote
i`ve also done the solution provided by eddie2k2
and has made a massive difference
tested it on a good hours drive
with only a very slight stutter every so often , if someone used it without knowing the original problems they`d me non the wiser
nice work and well done to all involved[/b]
Bukem
PostPosted: Fri Nov 19, 2004 7:14 pm    Post subject: Top Fella Reply with quote
Eddie2k2 i tip my hat to you sir!!
your solution has cured the double POI problem on the 6600
for me.
thanks !!!!!!!!! :D
Nelson
PostPosted: Sat Nov 20, 2004 2:07 pm    Post subject: Reply with quote
Hi.
Can anyone give me links to the programmes needed to do this? I cant seem to find them anywhere!
Cheers,
John
eddie2k2
PostPosted: Sat Nov 20, 2004 2:44 pm    Post subject: Reply with quote
here
http://www.tomtom.com/support/ce/support/ov2/ov2tools.zip
Nelson
PostPosted: Sat Nov 20, 2004 3:18 pm    Post subject: Reply with quote
Thats great. Thanks!
Page 3 of 4
22.044 (24 Apr 24)
