Pocket GPS World :: View topic - Help need for a newbi
vodkatart
PostPosted: Thu Oct 21, 2004 9:13 pm    Post subject: Help need for a newbi Reply with quote
hi everyone. iv just gone and bought a Dell axim x30 Pda which i must say im impressed with, anyway i decided to buy some navigation software and go for the sat nav. so i bought TomTom software and then bought a Emtac crux bluetooth GPS receiver, No the problem, the X30 connects to the GPS just fine via the bluetooth but the navigation system and GPS software will not pick any signal back ie no location given. My line of sight is spot on adn im getting v.frustrated. have i got a compatability isse here between the X30 and GPS receiver.
PostPosted: Thu Oct 21, 2004 9:16 pm    Post subject: Reply with quote
Can you please try a GPS utility (like WinFast Navigator or Crux_View) . You may have to de-install the TomTom GPS driver to get those to work. Once they are ok, you can re-install teh TomTom GPS driver v2.07 (from our downloads page)
lexuscol
PostPosted: Thu Oct 21, 2004 10:24 pm    Post subject: Reply with quote
I had a similar problem, then I discovered the snag with the help of the guys on this site, Q. When you installed tomtom did you tell it that you were using another type of GPS receiver. Once you tell it you have the option to select your receiver and com port and connection baud rate. I chose emtec comport 8 and baud 38400 tomtom then worked but kicked up an error on the bluetooth manager. I did as Lutz said and uninstalled tomtom~gps and installed driver 207 from the downloads section on this site. everything works ok now.
hope this helps
Good luck
Col
vodkatart
PostPosted: Thu Oct 21, 2004 11:24 pm    Post subject: Reply with quote
No signal from the GPs still after trying both of your ideas, Its been made even more frustrating by the fact that my mate has just used his PDA with Bluetooth via a CF card and it pick my GPS reciever up stright away and get a sigal ahhhhhh :x
Any moor idea guys thanks so far
PostPosted: Thu Oct 21, 2004 11:53 pm    Post subject: Reply with quote
Dell Axim - Have you actually done the BT Serial Registry fix?
vodkatart
PostPosted: Fri Oct 22, 2004 12:02 am    Post subject: Reply with quote
No i havent, i havent even picked up on that, is that on the dell site
PostPosted: Fri Oct 22, 2004 12:11 am    Post subject: Reply with quote
Have a read
http://www.aximsite.com/bluetooth/
vodkatart
PostPosted: Fri Oct 22, 2004 12:35 am    Post subject: Reply with quote
Cheers for the page. Iv had a read though and set everything up as discribed cound'nt find anything on the fix though. but anyhow still no joy this is getting a bit silly now
PostPosted: Fri Oct 22, 2004 12:52 am    Post subject: Reply with quote
When your friend connects to the BT receiver, does he get a position as well? Please verify with him if he is using the same protocol as you. Ideally you should select NMEA at 38400, and the standard outgoing port (whatever this is on the AXIM. Try not to use any of the TomTom "special" settings. And try not to use SiRF protocol.
22.055 (29 May 24)
