Pocket GPS World :: View topic - STA update
STA update
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Speedtrap Alert (STA)
RichardM
PostPosted: Tue Dec 13, 2022 5:54 pm    Post subject: STA update Reply with quote
I have just had to start using STA as i have got a new Samsung phone running Android 13. I have got STA on the phone but cannot get it to update to the current database. It has the one from 1/12/22, but I just get a message "update failed". It is probably something I am not getting right can anyone offer any help.
Many thanks
RichardM
PostPosted: Tue Dec 13, 2022 6:01 pm    Post subject: Reply with quote
Last 3 posts :
https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=99315&start=540
Satnav:
Garmin DS61 LMT-D (Indoor test rig)
Garmin 2599 LMT-D (Indoor test rig 2)
RichardM
PostPosted: Tue Dec 13, 2022 6:05 pm    Post subject: Reply with quote
Not sure what you mean by those posts. They only confirm the database update has been fixed. But something is not working for me
PostPosted: Tue Dec 13, 2022 6:13 pm    Post subject: Reply with quote
The last few posts do indicate the beta has been fixed and the production version will be updated soon.
In the meantime the old manual way works.
Satnav:
RichardM
PostPosted: Tue Dec 13, 2022 6:27 pm    Post subject: Reply with quote
Misunderstood, I thought the final version was up and running. I tried the manual way and have the download on the phone but it is not updating. I must be doing something wrong or missing a step
PostPosted: Wed Dec 14, 2022 5:30 am    Post subject: Reply with quote
Have you extracted the .txt file from the .zip ?
Satnav:
RichardM
PostPosted: Wed Dec 14, 2022 8:41 pm    Post subject: Reply with quote
I have updated STA to the latest version 1.2.6.1 (104) and tried the update button and it hasnít put up a failed message so I presume that I have the latest camera database.
PostPosted: Thu Dec 15, 2022 5:01 am    Post subject: Reply with quote
You can check via the settings database option to see the latest update date
Satnav:
RichardM
PostPosted: Thu Dec 15, 2022 4:04 pm    Post subject: Reply with quote
Yes. it looks OK, must have been the bug in the previous STA version.
On another note is there a way to do a trial run from home as you could with CamerAlert, to save driving the actual route to check if things are working properly?
PostPosted: Thu Dec 15, 2022 5:39 pm    Post subject: Reply with quote
Leo's post third from last :
Satnav:
RichardM
PostPosted: Thu Dec 15, 2022 8:14 pm    Post subject: Reply with quote
Yes I saw that.
Any idea how I do a trial run at home to check itís all working ok?
Leo_A
PostPosted: Fri Dec 16, 2022 10:40 am    Post subject: Reply with quote
RichardM wrote:
Yes I saw that.
If you see cameras along your route on the map, then everything is OK.
If you wish to "play" your route with STA, install one of the "mock locations" Apps from the Google play and test.
RichardM
PostPosted: Fri Dec 16, 2022 11:33 am    Post subject: Reply with quote
OK thanks for that. I can see the cameras, I just wanted to check the voice activation as it was not working when I originally tried without the phone connected to the car, probably a phone setting not quite right
Leo_A
PostPosted: Fri Dec 16, 2022 1:12 pm    Post subject: Reply with quote
You can test voice and sound without playing route or driving. There is 3-dots menu at the top-right and command 'quick test'. This command displays popup alert and plays voice with sound.
rimbim
PostPosted: Sun Jan 01, 2023 10:09 pm    Post subject: GPS location and speedometer not working properly Reply with quote
Thanks for the forum - I've used STA and PGPS for a long time. However it's only recently that STA on my Android 12 didn't work all the time. Praps it was after an update of it or Android. I could sometimes get the speedo and/or map to behave if I turned on the GPS first. Sometimes not.
Having just seen the ref to 'Use Google Play Services as the location provider', mine was set to the default setting. Changed this and Hey Presto. Will monitor to check it remains thus.
This should be highlighted in FAQ or setup guide. It seems that an update can screw this up. I certainly hadn't touched it!
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Speedtrap Alert (STA) All times are GMT + 1 Hour
You can post new topics in this forum
You can reply to topics in this forum
You can edit your posts in this forum
21.093 (20 Sep 23)
