jonial Regular Visitor
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Wed May 13, 2020 2:03 pm Post subject: Remove Duplicates Module error in Garmin CSV to GPX Converte |
I have run into a problem whilst trying to process the latest update.
The error message reads Conversion from string "latitude" to type "Double" is not valid. 13
I hope this is the proper place to ask for help please.
The programme has run perfectly for a long time _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
M8TJT The Other Tired Old Man
Posted: Wed May 13, 2020 2:46 pm Post subject: |
Yep. Here's as good a place as any.
I'll have a go on mine in a bit and I expect the author Kremmen will be along before long.
OK. Just downloaded and process latest DB. No problem.
Base CSV cams = 14,930
Removed 1247
Processed 13,683
Total GPI cams 17,672
Presumably you have tried a fresh D/L and unzip? |
Posted: Wed May 13, 2020 2:57 pm Post subject: |
I have tried fresh downloads and unzips still the same.
It is strange as nothing has changed on my PC _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Wed May 13, 2020 3:10 pm Post subject: |
My apologies
I should have said that the files are unzipped in the CSV Direction Converter and they are processed in the Converter and then the failure occurs when trying to process them in the CSV to GPX Converter. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Wed May 13, 2020 3:11 pm Post subject: |
I assume that you are using the program to download and unzip the PGPSW file are you.
I only ask, as some people unzip it 'by hand' rather than using the prog, and it don't work like that. |
Posted: Wed May 13, 2020 3:36 pm Post subject: |
Yes downloaded and unzipped in the Direction converter. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Kremmen Pocket GPS Verifier
Joined: Mar 03, 2006 Posts: 6640 Location: West London & Reading
Posted: Wed May 13, 2020 4:12 pm Post subject: |
Very odd.
I had a trip to do yesterday (Tues) so I downloaded the latest and used the Converter without issue Mon evening.
That error is saying that it's found a file that still has the "Latitude" in the top line. Part of the Converter unzip routine is to remove that 'header' line.
Can you check you don't have any existing rogue CSV files.
2) Are you using your same location so we know it's read/write OK
3) As the Converter is running is shows progress, can you tell from that what file it's having issues with. _________________ Satnav:
Viofo A119 V3 |
Posted: Wed May 13, 2020 4:25 pm Post subject: |
Hello Kremmen
How do I check for rogue files?
The problem occurs after I have clicked the Green Process button the Columns turn light green and the erro message appears.
Hope this helps _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
dales Frequent Visitor
Joined: May 04, 2008 Posts: 743 Location: Knaresborough, North Yorkshire.
Posted: Wed May 13, 2020 4:29 pm Post subject: |
It's doing it for me.
Each pmobile file (except an empty one) - its contents look to be doubled up, with a rogue line half way down - longitude latitude name.
Dales _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Wed May 13, 2020 4:34 pm Post subject: |
Ah, thanks D
I don't download mobiles, hence why I didn't have the problem.
Is it a PGPSW rogue file problem ? _________________ Satnav:
Viofo A119 V3 |
Posted: Wed May 13, 2020 4:36 pm Post subject: |
... and is it last weeks file or todays new one _________________ Satnav:
Viofo A119 V3 |
Posted: Wed May 13, 2020 4:48 pm Post subject: |
The version that fails for me is dated06/05/2020. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Wed May 13, 2020 4:54 pm Post subject: |
Hopefully corrected with today's update, later.
Surprised it's taken a week to spot, obviously, like me, haven't needed it _________________ Satnav:
Posted: Wed May 13, 2020 4:55 pm Post subject: |
It's the file for 6.5.20 (the latest the Converter can see).
The PGPSW file looks OK.
And I've just deleted all csv files in the Converter folder, rerun the programs, and all is working OK.
Very strange ! _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Wed May 13, 2020 4:59 pm Post subject: |
Not PGPSW, yes, very odd.
Got me beat _________________ Satnav:
Viofo A119 V3 |
