Pocket GPS World :: View topic - POI warning.
POI warning.
BERTIE
PostPosted: Tue Oct 12, 2004 3:22 pm    Post subject: POI warning. Reply with quote
In TomTom Go does the POI audible warning (Speed Cams) only work when a route is planned.
When just using the 3D map with no route planned I can see the POI but get no warning. If a route is planned I get an audible warning. Can I set it up to do this please ?
lbendlin
PostPosted: Tue Oct 12, 2004 4:21 pm    Post subject: Reply with quote
Works fine for me. Are you sure you have alerting enabled for that particular POI category? It is done by category, not in general.
Make sure your sound volume is sufficient, too.
Lutz
TomTom/TeleAtlas NAVTEQ
BERTIE
PostPosted: Tue Oct 12, 2004 4:31 pm    Post subject: POI warning. Reply with quote
Yes done all that but still no audible warning.
lbendlin
PostPosted: Tue Oct 12, 2004 4:38 pm    Post subject: Reply with quote
I can try again on the way home but it is well possible that when you're idling along (not actively routing) all you get is the flashy icon and the distance indicator.
Keep in mind this system is to be used for navigation, not for cruising.
Lutz
T3user
PostPosted: Thu Oct 14, 2004 5:43 pm    Post subject: Re: POI warning. Reply with quote
Hi Hope this helps, I also had the above problem, but if you go into poi management, and edit the poi's ( warnings) it asks you if you want the warning to sound only when the camera is on a set route, if you untick this, the warning will be given even if you dont have a route running.
So far its worked great for me...........
lbendlin
PostPosted: Thu Oct 14, 2004 6:10 pm    Post subject: Reply with quote
Yes, I can confirm that the oink oink also works for custom POIs, but only if they are on the route (which you don't have when you idle along) or if you do as T3user says.
Lutz
22.053 (15 May 24)
