Pocket GPS World :: View topic - Camera marked with red cross
Goto page Previous  1, 2
PostPosted: Thu Jul 06, 2017 6:26 pm    Post subject: Reply with quote
@MaFt. Are you onto this one?
PostPosted: Thu Jul 06, 2017 6:36 pm    Post subject: Reply with quote
It sounds like a reversible Truvelo then.
Best way is to change it on the submission map to reversible so MaFt picks it up next Wednesday.
@b33, if you are using stock CSV via POILoader then cameras are often not announced if you are under the limit and not accelerating.
b33jay
PostPosted: Thu Jul 06, 2017 7:52 pm    Post subject: Reply with quote
I had realised that is probably why the speed difference created a voice warning for the fixed camera. It seems that the close proximity of two conflicting sources is unusual.
Reversible operation makes sense as although there is nothing beyond the Academy car park entrance/exit eastbound and NSL start 200 metres beyond it covers traffic entering and lesving the school.
Many thanks to those who commented. I have learned to increase scale to separate possible overlapping cameras and to check the visual indication as well as the audio warning but, more importantly, the camera is updated.
Daggers
PostPosted: Thu Jul 06, 2017 8:28 pm    Post subject: Reply with quote
sussamb wrote:
Depends which Truvelo, original ones were forward facing only. If that one has been there for a while it will be forward facing.
Depends what you mean by "for a while". The reversible ones have been around for at least 10 years, as I know to my cost. We should not be referring to Truvelos as "forward-facing". See this thread: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=57093&highlight=truvelo
Garmin DriveSmart 50 LMT-D
PostPosted: Thu Jul 06, 2017 8:44 pm    Post subject: Reply with quote
You do not have two cams in close proximity.
The ones with the red cross on the submission map are not in the camera database download.
The reason that they are shown is so that you can easily see if they were in the database in the past and use that to submit a 'seen again' which will 'revive' the cam and make it active again in the next updated download.
If you are using the 'standard' POILoader download, the Garmin will queue alerts so, in the case of two cams close to each other, you will get alerts one for each camera and if you are a little over the speed limit you get 4. This can be a pain on a motorway with cams on both carriageways on the same gantry.
If you use Kremmen's CSV to GPX converter, you will have not only proper voice spoken alerts, but it will also get rid of the multiple alerts from adjacent cams (amongst other things)
PostPosted: Thu Jul 06, 2017 9:08 pm    Post subject: Reply with quote
Yes, cameras can be reversible but that doesn't make them rear facing cameras, just forward facing ones pointing in a different direction. As far as I know the Truvelo cameras that are both rear and forward facing were introduced in 2013.
https://www.speedcamerasuk.com/truvelo-d-cam.htm
Daggers
PostPosted: Thu Jul 06, 2017 9:25 pm    Post subject: Reply with quote
I can assure you this one was used as a rear-facing camera. I saw the photograph which snapped me in 2007. ... And I wasn't reversing!!
PostPosted: Thu Jul 06, 2017 9:36 pm    Post subject: Reply with quote
Then I must be wrong Wink
Page 2 of 2
