Pocket GPS World :: View topic - Nuvi 3598 Traffic Problem
Chinster1957
PostPosted: Mon Feb 06, 2017 10:43 am    Post subject: Nuvi 3598 Traffic Problem Reply with quote
Hi. Not sure if anyone can help with this. I have a Nuvi3598 and it has just started to misbehave. It no longer throws up the traffic information on the right of the screen. Traffic is being registered by the unit because if I manually hit the traffic button it does display correctly, but it refuses to automatically show the traffic without manual intervention. It started happening mid journey. It was working ok, then we stopped for a rest. When we restarted our journey the traffic would not work correctly. I have tried a hard reset and that hasn't helped.
Any ideas, please?
BAVC10
PostPosted: Tue Feb 07, 2017 12:16 am    Post subject: Reply with quote
If the traffic displays when you manually select it then the GTM traffic c adapter must be working. Normally traffic will only automatically show if there is traffic
On your route
Did you have a route selected at the time? What do your settings say for the traffic options in the menu?
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
Chinster1957
PostPosted: Tue Feb 07, 2017 10:39 am    Post subject: Reply with quote
Yes a route was selected. This has happened more than once each time with a route selected.
The Traffic settings haven't changed. I have "Optimise Route" set to On Request, "Traffic Alerts" set to Most, "trafficTrends" turned off.
I also have the Traffic Map Layer ticked.
Its odd because it stopped working mid-route.
The device knew about the problems on the route because it was amending the end time correctly, it just wasn't showing it on the display unless I pressed the traffic button.
BAVC10
PostPosted: Tue Feb 07, 2017 12:20 pm    Post subject: Reply with quote
Has the Traffic - compatible traffic accessory required become unticked by any chance - not sure why it would stop working en route.
Chinster1957
PostPosted: Tue Feb 07, 2017 2:12 pm    Post subject: Reply with quote
No that's still ticked. Odd isn't it.
Dabri
PostPosted: Tue Feb 07, 2017 5:57 pm    Post subject: Reply with quote
Have you possibly added another map to your unit? My 3598 suddenly decided that it would not provide traffic at all after I added a TalkyToaster map. Removing the offending map returned the traffic function.
Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v6.80; Samsung A52.
PostPosted: Tue Feb 07, 2017 7:06 pm    Post subject: Reply with quote
I have a TT map loaded and no traffic issues Confused
Dabri
PostPosted: Tue Feb 07, 2017 7:10 pm    Post subject: Reply with quote
I have three additional maps on my 2460 with no problem, but on the 3598 the software recognises them and throws a wobbly, viz. it either says the power lead will not charge, or it disables traffic.
Dabri.
PostPosted: Tue Feb 07, 2017 7:36 pm    Post subject: Reply with quote
Ah OK, maybe a model specific issue then.
Chinster1957
PostPosted: Tue Feb 07, 2017 10:06 pm    Post subject: Reply with quote
No additional maps have been added. It's all very strange.
pcaouolte
PostPosted: Wed Feb 08, 2017 9:00 am    Post subject: Re: Nuvi 3598 Traffic Problem Reply with quote
My Drivesmart 50 LMTD does the same thing. If you deviate from the planned route, even slightly, when the unit recalculates the route the traffic is no longer displayed.
Paul
BAVC10
PostPosted: Wed Feb 08, 2017 10:31 am    Post subject: Reply with quote
Perhaps worth installing the latest firmware 5.10 as this mentions you recalculating on a route so maybe that could also affect traffic
Chinster1957
PostPosted: Wed Feb 08, 2017 12:21 pm    Post subject: Reply with quote
Currently on version 5.4. Just been on a journey. On the way there the traffic didn't bring up the right hand screen even though there was traffic on the route. Coming home, as soon as I attached the unit the traffic started working as expected. Could it be a problem with dirty pins on the magnetic holder maybe?
PostPosted: Wed Feb 08, 2017 12:45 pm    Post subject: Reply with quote
YES. Clean them with meths or similar.
Chinster1957
PostPosted: Wed Feb 08, 2017 3:29 pm    Post subject: Reply with quote
Thank you. I will give that a try.
22.052 (08 May 24)
