RichieRich12 Occasional Visitor
Posted: Mon Dec 12, 2016 3:31 pm Post subject: Do I need up-to-date maps? |
This question has probably been asked a thousand times already but I couldn't find the answer anywhere, apologies in advance if it has.
Do I need up-to-date maps (TomTom) in order to use the Speed Camera Database?
I'm guessing that the answer is no and if the maps are out of date then it simply would affect the accuracy of the camera positions etc?
Thanks |
DennisN Tired Old Man
Posted: Mon Dec 12, 2016 3:50 pm Post subject: |
Correct _________________ Dennis
Two of them are obesiting!! |
M8TJT The Other Tired Old Man
Posted: Mon Dec 12, 2016 4:57 pm Post subject: Re: Do I need up-to-date maps? |
RichieRich12 wrote: | and if the maps are out of date then it simply would affect the accuracy of the camera positions etc? | Only if they are on new roads not on your old map. Otherwise all will be OK. |
Posted: Mon Dec 12, 2016 5:15 pm Post subject: |
Thanks for the quick replies chaps. |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Tue Dec 13, 2016 10:40 am Post subject: Re: Do I need up-to-date maps? |
M8TJT wrote: | Only if they are on new roads not on your old map. Otherwise all will be OK. |
I think that new roads not on your map will only be a problem if you use "Warn on route" if you just use normal proximity alerts then you will be OK most of the time.
The exception may be when TomTom unit "snaps your location" onto a known road. Say you're on a new road bypass that is close to the old road. TomTom may snap your location onto the old road which may show you a small distance away from the actual speed camera on the new road.
As a subscriber to the database you are entitled to use CamerAlert for either iPhone or Android which you can use as an additional warning.
Garmin Camper 770 LMT-D |
