taff_x Occasional Visitor
Posted: Mon Dec 28, 2015 12:15 pm Post subject: Please help - 2015 Suzuki Vitara SZ5 |
I'm just in the process of ordering a new 2016 Suzuki Vitara SZ5 with built in sat nav. From a hour test drive it is evident that the sat nav does not have a built in speed camera alert. I was just wondering if the PocketGPSWorlds speed camera database would be compatable and if so which database would i install to put speed camera on the built in sat nav.
Thanks for reading and your askers/help is very much appreciated.
Thanks  |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1054 Location: The green bit between the M40, M4 and M25.
Posted: Sun Jan 03, 2016 2:26 pm Post subject: |
Not a Vitara driver so can't give a definite answer for you.
From other similar posts on the forums about 'in car' satnav systems,, there aqre a couple of things you need to find out from Suzuki.
What is the exact model of the satnav in your car, they change from model to model even within the same car maker.
And, does the satnav accept 3rd party POIs, and if so, how do you applyy them.
Do a search of these forums some / all of the answers may be here.
I drive and Audi, Vauxhall befotre that and just couldn't be bothered with the in car system for PGPSW, just used my phone, easier to keep updated as well.
Just my 2 bobs worth. Good luck.
Bob _________________ Triumph Tbird 1700. And now a Bonnie T100 as well. |
Posted: Sun Jan 10, 2016 10:06 pm Post subject: |
Thanks for the reply 253.
I have taken your information on board and this the information that I have got back is it is a Bosch SLDA system with open source software it looks like it accepts .csv files.
This is the official site. http://www.suzuki-slda.com/ POI information is found in the user manual on pages 52/53
Does it sound like I should be able to use the Camera database?
Thanks[/img] |
M8TJT The Other Tired Old Man
Posted: Mon Jan 11, 2016 12:45 am Post subject: |
Seems like it. You can also set up warnings, so it would appear that it's OK to give warnings for the cams, but there isn't much of a clue as to the distance, |
Posted: Tue Mar 01, 2016 9:12 pm Post subject: |
Ok I may be being thick, but I have had the day off so I have been try to get pocketsgps data base to work all day on my New Suzuki Vitara S but I'm still coming up blank.
I have followed all the online info on http://www.suzuki-slda.com/SitePages/Home_Suzuki.aspx
down loaded the .csv info off the poscketgps site, put the files in a file call myPOIs(as suggested on the site) and then renamed all the .csv files with myPOIWarnings_.......csv (as suggested on the site) but no sure luck.
Does ANYONE have any helpful ideas?
Thanks taff_x |
Posted: Sun Mar 06, 2016 9:45 pm Post subject: Can anyone help |
Ok I seem to have got a little further I can now see myPOI and navigate to them but I am still not able to see them on my sat nav while driving alone, either when i have a route inputted or not.
Can anyone help? |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 726 Location: Knaresborough, North Yorkshire.
Posted: Mon Mar 07, 2016 12:46 am Post subject: |
Just a thought, since nobody else is chipping in yet. This may not work, but it's well worth a long shot. (This following method of having matching pairs of .csv's and .bmp's is how all Garmin pnd's work). It cannot harm anything.
If there is nothing on your screen for the PGPSW cameras, then the system seems to be short of an appropriate icon to display.
[However the manual does say that, if set to On, "the system issues the point of interest warning by displaying a symbol".
Do you not get this symbol? You will have set this warning to On, yes?].
The Suzi has a list of built-in icon symbols at para 14 of the manual, but none of these is for Custom POIs. Presumably users are expected to supply their own icons for these, so as to make them display on the screen.
Alongside your csv's, you might try loading up the PGPSW .bmp files that should have come with your download. These are the icons associated with Gatso, Mobile etc. You will need to rename these exactly as you renamed the camera csv files. You will have matching pairs of .csv's and .bmp's, identically named apart from the extension.
This just might work - it is always a process of experimentation with factory-fit systems.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Mon Mar 07, 2016 9:22 am Post subject: Re: Can anyone help |
taff_x wrote: | Ok I seem to have got a little further I can now see myPOI and navigate to them but I am still not able to see them on my sat nav while driving alone, either when i have a route inputted or not. | These symptoms seem to be the same as recent TomTom devices. |
Posted: Mon Mar 07, 2016 9:39 am Post subject: Re: Can anyone help |
M8TJT wrote: | taff_x wrote: | Ok I seem to have got a little further I can now see myPOI and navigate to them but I am still not able to see them on my sat nav while driving alone, either when i have a route inputted or not. | These symptoms seem to be the same as recent TomTom devices. |
Was there any solution found?? I'm open try anything.
Ps Thanks Dale. I will try those things tonight when I finish work. |
Hairy Lifetime Member
Posted: Tue Apr 26, 2016 12:26 pm Post subject: |
This is the issue I'm trying to deal with. The distributor I bought the car from knows nothing about computers so hasn't been able to advise me. Looking at all the available programmes on the speedbase page, Demon 2 seems the closest. After downloading it onto my computer to transfer, it states that there is no sound files attached, so that will be no good.
If you succeed, please let me know how. |
Posted: Tue Apr 26, 2016 1:18 pm Post subject: |
The only thing I have come up with is download the detonator 3 (.csv file), the single file with all cameras.
With that file I unzip it to a folder called MYPOIs and the .csv file that is put in there i rename myPOIWarnings.csv, I then delete any other files that are transferred to the folder I then delete.
This folder I then copy on to a USB stick which i use to transfer the folder to headhunt.
I hope this helps. |
Posted: Tue Apr 26, 2016 4:33 pm Post subject: |
Yes I have looked at that file, but, according to the instructions, there are no sound files attached. |
CAA_0516122728 Occasional Visitor
Posted: Mon May 23, 2016 2:20 pm Post subject: |
Just wondering if you had any success with this. I am trying to do the same thing with mixed success.
I have downloaded the csv and can see a list of camera sites using the myPOIs nearby option.
On two occasions after loading the file I got a message and an icon of a camera on the map but these disappeared when I restarted the engine.
I don't know where the camera icon came from though I called my file myPOIWarnings_Cameras.csv and put the file in a folder named Cameras which was a sub-folder of myPOIs.
Interestingly someone in France has put something on Youtube showing the system working though he does say that he has to reload the file every time he starts the engine. It is in French but worth a look at the video - site is https://www.youtube.com/watch?v=3al6w30Ecnw |
Posted: Wed May 25, 2016 2:57 pm Post subject: |
Have at last got it to download have not tried it . Look at nissan connect download and installation guide |
mrgrimsby Regular Visitor
Posted: Thu Mar 16, 2017 10:00 pm Post subject: |
Hairy wrote: | Have at last got it to download have not tried it . Look at nissan connect download and installation guide |
Did anyone get this to work? I have vitara 1.4 boosterjet and would love a idiots guide if anyone could help me? Thanks
Peter |
