Kremmen Pocket GPS Verifier
Posted: Thu Oct 22, 2015 11:06 am Post subject: |
New program version posted (same link)
When installed top banner should be 2015.10.22.20
It needed:
Adjacent - Allowed
Unverified - Included
I also found a dummy Specs camera as well.
I've coded it so if any camera doesn't have any @xx data then it will be skipped. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
Posted: Thu Oct 22, 2015 11:46 am Post subject: |
But I want to cut out the adjacent. That's part of the whole point?????
Have you checked to see if there are any valid cameras that don't have an associated speed? |
Posted: Thu Oct 22, 2015 12:06 pm Post subject: |
The reason it was working for me is that I wasn't opting to use the unverified camera sets. Why the allowing adjacent had an influence I'm still looking at.
I've coded it to bypass any cameras with no valid internal data (no @xx ). When I ran it through in debug mode it only found 2. The one in the error post and another similar Specs dummy.
No others came to light.
The program is quite complex so trying to test all combinations is horrendous. Hence the comprehensive error trapping. _________________ Satnav:
Car Average MPG :
DEANO3528 Lifetime Member
Posted: Thu Oct 22, 2015 12:50 pm Post subject: |
Kremmen wrote: |
I've coded it to bypass any cameras...
When I ran it through in debug mode...
The program is quite complex so trying to test all combinations is horrendous. Hence the comprehensive error trapping. |
And there was me thinking I was slightly knowledgeable about such matters because I can create a website in Joomla |
Posted: Fri Oct 23, 2015 7:18 am Post subject: |
Allowing adjacent is (was) involved because in the dummy created file the last line of the file had the same coordinates as the dummy camera so the dummy camera was removed.
Double check was to ensure that both the first and last camera are in the GPX files, which they are.
Panic over, current version stands pending user reports. _________________ Satnav:
Car Average MPG :
