SamIOW Occasional Visitor
Posted: Thu Oct 08, 2015 10:23 am Post subject: Promlem trying to plane a route 2699 nuvi ltm -d |
Good Morning,
Please excuse if this has been covered before, BUT I am at a loss and would dearly like some help advice please.
I have just bought a Garmin 2699 nuvi ltm -d , I used to have a TomTom go 910,
The route I will to plan is from the IOW to Ashill in Thetford But not using the M25, I want to go Winchester,Newbury,Didcot,Oxford,Bicester,Bletchley,Cambridge,Newmarket,Thetford, etc,
The option I used where to,categories,Address,,postcode,house number, I then select routes which should give me options for other routes? but come up with no other routes which is wrong surely?
Sorry for such a long drawn out thread.
Sam |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Thu Oct 08, 2015 11:41 am Post subject: |
I've replied to your PM, but just seen this post.
I suspect it's not offering other routes as they don't make sense, given your routing and avoidance options. If you want to go the way you want then you'll need to put in some via points.
You can do this two ways. Use the trip planner app or do a where to and initially enter Ashill. Press Go so you're nuvi has that route active. Now do another where to and select a point on the route you want and then go again. You'll be asked if you want to add it to the active route or start a new route. Select the active route option.
Adding Bicester gave me the route you seem to want. _________________ Where there's a will ... there's a way. |
Posted: Thu Oct 08, 2015 12:09 pm Post subject: |
Thanks, for that but I panicked and called them and had a little moan, I was then told that the way to go was using the trip options in apps, which is what I did but selected Oxford and got the result I wanted, still having a problem with basecamp though! |
Posted: Thu Oct 08, 2015 12:19 pm Post subject: |
Basecamp is easy with a bit of practice, if you have a particular problem open another thread and I'm sure someone here can help. _________________ Where there's a will ... there's a way. |
M8TJT The Other Tired Old Man
Posted: Thu Oct 08, 2015 3:00 pm Post subject: |
I quite like the idea of planeing a route. Saves driving it. |
Kremmen Pocket GPS Verifier
Posted: Thu Oct 08, 2015 3:35 pm Post subject: |
That would set a few Gatso's off. _________________ Satnav:
Car Average MPG :
Posted: Thu Oct 08, 2015 6:37 pm Post subject: |
Kremmen wrote: |
That would set a few Gatso's off. |
is that a bad route for Cams? |
Posted: Thu Oct 08, 2015 7:45 pm Post subject: |
OK. I'll spell it out.
You made the title of this thread "Problem trying to plane a route..." rather than "Problem trying to plan a route..." |
Posted: Thu Oct 08, 2015 8:09 pm Post subject: |
M8TJT wrote: | OK. I'll spell it out.
Thanks for that, Typo, But good to know they work on planes too |
