eddieo Regular Visitor
Posted: Thu Jul 16, 2015 11:08 am Post subject: 2547. cant delete anything within Trip planner App? |
nuvi 2547. cant delete anything within Trip planner App?
trying to delete past routes and I dont seem to be able to within the app..any ideas please as trying to organise a Euro tour for next week
i select everything ticking in all the boxes. press delete and nothing all happens? |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Thu Jul 16, 2015 11:13 am Post subject: |
Select the trip in trip planner app. Tap icon top left and select delete. _________________ Where there's a will ... there's a way. |
Posted: Thu Jul 16, 2015 11:23 am Post subject: |
I dont understand that works..but I tried everything and it seenmed locked up
thanks so much...thats about 15 pints I owe you |
Posted: Thu Jul 16, 2015 12:19 pm Post subject: |
Hmmm. I am now getting "cannot calculate route" after attempting to. I have cut section down to approx 300 miles and it still refuses to calculate..any ideas plse?
Spain this spring:
After the route I downloaded from Mapsource (cant for the life of me get on with basecamp!) sending down the wrong roads (even when maps on device and Mapsource the same) My mate said he just does in the trip planner App on the device. I used this for getting home from Spain and it worked perfectly!
so trying to sort this route out now |
Posted: Thu Jul 16, 2015 1:10 pm Post subject: |
maybe I should ask how many miles does route need to be limited to in the App plse? |
Posted: Thu Jul 16, 2015 1:11 pm Post subject: |
A 300 mile trip is a big ask. I'd try to split it into two. _________________ Where there's a will ... there's a way. |
Posted: Thu Jul 16, 2015 1:26 pm Post subject: |
sussamb wrote: | A 300 mile trip is a big ask. I'd try to split it into two. |
even though in the App im calculating between two points in say germany, I think its failing because its calculation is from here in London. forgotten how to turn of GPS and place myself somewhere on route
found the GPS simulator but it dont seem to work within the App as cant select a start point?
Posted: Thu Jul 16, 2015 1:29 pm Post subject: |
No hard and fast rule on max distance as it depends on other factors like complexity of route. _________________ Where there's a will ... there's a way. |
Posted: Thu Jul 16, 2015 1:39 pm Post subject: |
sussamb wrote: | No hard and fast rule on max distance as it depends on other factors like complexity of route. |
yes I get that..but while I have gps simulator on. it wont let me calculate between two waypoints but does it from london first making route really lonhg and thats why its failing. I cant seem to put myself in the point in germany where im trying to start section of route?
edit. it wont even calculate a 70 mile route |
Posted: Thu Jul 16, 2015 4:32 pm Post subject: |
OK solved. it was a waypoint that device did not like! the new road that this waypoint is on which is on both updated maps on device and PC... it just refused to route to this is what caused the confusion. moved waypoint back to main road and fine
I also got a firmware update during this (2nd in 2 weeks?) and now delete in trip planner working again |
Posted: Thu Jul 16, 2015 4:35 pm Post subject: |
Are you using trip planner? That should calculate wherever you are unless you hit a Go to if in London and route is in France/Spain
To set your location in GPS Simulation Mode hit where to and select the location, you should then see a button bottom left 'Set location'. _________________ Where there's a will ... there's a way. |
Posted: Thu Jul 16, 2015 5:33 pm Post subject: |
sussamb wrote: |
To set your location in GPS Simulation Mode hit where to and select the location, you should then see a button bottom left 'Set location'. |
thats the trouble when you only do 2/3 big trips a year ..I forget
I have also forgotten how to find downloaded custom routes in device? |
Posted: Thu Jul 16, 2015 8:35 pm Post subject: |
Should appear in trip planner app under unscheduled trips. _________________ Where there's a will ... there's a way. |
