Pocket GPS World :: View topic - CoPilot Wishlist
CoPilot Wishlist
PostPosted: Thu Sep 23, 2004 7:35 am    Post subject: Reply with quote
DavidW wrote:
Number 3 will be tricky - I looked into backlight matters to answer another question in the forums a while back. My reading of the Microsoft documentation is that Pocket PC, and the Windows CE operating system underneath it, doesn't give application software any control over the backlight save for possibly being able to change the "timeout" figures on battery and AC power (over that, there's a little lack of clarity - it may be possible for programs to change these figures using the same registry keys and system event that the Backlight Settings panel uses).
I think it's possible as they're doing it on the SmartPhone versions. It's probably a manual toggle of turn brightness up and then turn it down, but it does work, no reason why it couldn't work on PPC.
Robin2
PostPosted: Wed Sep 29, 2004 5:48 pm    Post subject: Reply with quote
1. Slightly higher speech volume (CP5 is an improvement over CP4, but not quite as loud as TTN3
2. Ability to select speeds for different types of road (I think the motorway speed is set to over 70 mph ...my ETA keeps moving back when I am cruising at a gps 70mph on the motorway using cruise control)
3 Improved 3D display
4. The yellow arrow completely obscures detail at roundabouts etc
Robin
xda
PostPosted: Thu Sep 30, 2004 4:13 am    Post subject: Reply with quote
The ability of TTS to be able to pronounce St. Michaels Grove as Saint Michaels Grove instead of S T Michaels Grove and the same for any other street names that use the abreviation St. for Saint.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
johnbarnes
PostPosted: Thu Sep 30, 2004 2:19 pm    Post subject: Reply with quote
My wishlist after using CoPilot Live 5 for a couple of weeks:
1. At all full-size roundabouts, whatever additional guidance is given, the voice instructions should always include "Take the first {second] [third etc.] exit" as required.
2. Offer lane guidance where appropriate.
3. When I am finding a location, skip the country question - I have only UK maps loaded.
4. Get TTS to pronounce St. at the beginning of a street name as "Saint".
5. Have "Speed Limit" available as a display item.
John
mark1968
PostPosted: Tue Oct 05, 2004 6:30 pm    Post subject: Reply with quote
I would like to see the following added.
POI Icons staying on the 3D and Next view when the car is moving.
Louder voice to text.
Ability to save current location by pressing one function button.
Option to select screen view without having to go into the safty screen first.
Option to change the POI Icons.
Please follow me on twitter @mdyson1968
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
xda
PostPosted: Wed Oct 06, 2004 2:34 am    Post subject: Reply with quote
Ability to change the default Safety screen from <5 mph to a user defined speed that it diplays at.
Graham.
Nokia 925 Windows 8
PostPosted: Tue Oct 19, 2004 10:27 pm    Post subject: Reply with quote
Another for the wishlist...
Ability to fine tune the routing algorithm at the client end by dialling in a percentage preference on:-
- Motorways
- A roads
- B roads
- C roads
4 sliders in all and this would help in users being able to tweak more their own routing algorithms.
mark1968
PostPosted: Wed Oct 20, 2004 10:42 am    Post subject: Reply with quote
Routing including one way streets.
TomTom does this already, but I have noticed that CoPilot seams to ignore this mapping information and tries to send you down the wrong way!!
PostPosted: Thu Oct 21, 2004 7:16 am    Post subject: Reply with quote
It's probably an issue with a road or two, or a specific area because CoPilot doesn't try to route me the wrong way down one-way streets.
mark1968
PostPosted: Thu Oct 21, 2004 9:10 am    Post subject: Reply with quote
I was in central london. Around by the Blackwall tunnel.
It looked like these roads had been part of a one way system for a while judging by the state of the signs.
ohm62
PostPosted: Thu Nov 04, 2004 7:22 pm    Post subject: Always mention exit numbers on Highways, please! Reply with quote
For the US version, when driving off state or interstate highways, signs always clearly indicate an exit number, and not necessarily the trivial road name nor sometimes the first destination and the main destination of the road, which is what Copilot uses for reference.
I would like Copilot to indicate those exit numbers on the map and in driving directions, both written and spoken out!
The absence of this basic information got me in trouble a number of times: once one gets onto the wrong ramp, it is often quite difficult and time consuming to get back on the highway, particularly in urban locations!
prusling
PostPosted: Fri Nov 05, 2004 1:05 pm    Post subject: Reply with quote
A few more CP5 wishes, posted elsewhere but also copied here for completeness:
- Mute function (e.g. when receiving a phone call)
- Brightness control (I'd prefer this on the left-right rocker to day/night)
- If you choose to detour from a planned route, CP5 tries to route you back onto it for too long
- Make the road number legend boxes the same size as the text, or at least position the text in the centre of them
- Waypoints are transferred from PC to PDA as stops rather than waypoints, and have to be converted
- Easier trip transfer to PDA (doing this manually at present)
Peter
ohm62
PostPosted: Mon Nov 08, 2004 3:30 pm    Post subject: Reply with quote
Ability to fine tune road type choices depending on the context (allow for separate choices for urban environment, where highways avoiding traffic might be preferable or for the countryside where small scenic roads could be the best option...)
prusling
PostPosted: Fri Nov 12, 2004 1:42 pm    Post subject: Reply with quote
The direction arrows are not fully displayed in Next Turn view when approaching a junction in North Up mode; this is particularly noticeable when traveling East or West.
BTW otherwise this is a great view option, which I only recently discovered; the reason I use North Up with it, is that it switches between North Up and Direction Up according to the distance to the next turn and I find this confusing.
mark1968
PostPosted: Sun Dec 05, 2004 2:58 pm    Post subject: Reply with quote
Does anyone have a eta on when some of these issues may be resolved, or are we going to have to wait until the next release?
If so do we know when this may be?
Page 3 of 4
