Pocket GPS World :: View topic - Comand will not load sd card
ROO90
PostPosted: Mon Mar 17, 2014 5:03 pm    Post subject: Comand will not load sd card Reply with quote
I have the Ntg4.5 command in my 2013 e class , the system will not load from the sd card have been trying all day but with no success
PostPosted: Mon Mar 17, 2014 5:16 pm    Post subject: Reply with quote
Have you have been exactly following the instructions here especially step 8? If so, it might be good to mention at which stage it fails.
ROO90
PostPosted: Mon Mar 17, 2014 5:57 pm    Post subject: Reply with quote
Could you advise as regards the term unpack, I extracted the files or so I think The files do not start to unload at all
PostPosted: Mon Mar 17, 2014 6:56 pm    Post subject: Reply with quote
Unzip or extract is another word for it. It's these Apple fanboys that use terms that not many people understand. I'm surprised that it bandied about here as the downloads come in the *.zip files and thus require un-zipping.
At which point is the procedure failing?
ROO90
PostPosted: Mon Mar 17, 2014 7:17 pm    Post subject: Reply with quote
Comand does not start to import data when sd is inserted
PostPosted: Mon Mar 17, 2014 7:46 pm    Post subject: Reply with quote
Then it seems like it is possible that you are doing something wrong.
Have you got the folder name right in step 1? It should be PersonalPOI. Note: No space.
Have you unzipped the files into the PersonalPOI folder. It should now contain, amongst others, files names pocketgps_uk_sc.gpx and pocketgps_uk_pmobile.gpx. Can you see these two files on the SD card?
If so, at which step does it not do what you are expecting it to do. (Use the step number in the instructions as a reference)
From the instructions, Command will NOT automatically start to import the data when the SD is inserted. You have to do the stuff in the instructions, like steps 20 - 23. Are you doing this?
ROO90
PostPosted: Mon Mar 17, 2014 8:07 pm    Post subject: Reply with quote
Yes I can see the files on sd card, but step 24 does not happen
PostPosted: Mon Mar 17, 2014 8:36 pm    Post subject: Reply with quote
Ah, right. I don't have the Merc system, so can't really go any further. If you are absolutely sure that you have the correct folder name and the correctly named *.gpx files within that folder on the SD, then the only things that I can suggest further is that you delete all the other files out of the POI folder on the SD except the *.gpx files and/or try a different SD card.
Just had another thought. Thinking out loud really. Are you using an SDHC card and if so, does it matter or should it be a bog standard SD card? Should the 8Mb suggestion in the instructions be 8Gb? Anyone???
ROO90
PostPosted: Sat Apr 19, 2014 7:02 pm    Post subject: Reply with quote
BUMP
Still need help with this , have tried all the above suggestions all to no avail command system will not import data from SD card
Any Merc owners able to help Sad
GerryC
PostPosted: Sat Apr 19, 2014 7:46 pm    Post subject: Reply with quote
Just a thought. When extracting/unzipping/whatever the files, are they going into a sub-folder of PersonalPOI or staying in the same folder? I don't have the system but suspect they need to be in the folder itself and not a sub-folder.
Some extraction utilities will create a new folder by default unless you tell it otherwise. Is also try using an otherwise blank SD card just in case it makes a difference.
Gerry
ROO90
PostPosted: Mon Apr 21, 2014 8:04 am    Post subject: Reply with quote
pam3059
PostPosted: Thu Jun 26, 2014 9:28 am    Post subject: Mercedes command Help Reply with quote
Did you manage to solve your problem, I am having the same trouble with my 2013 E class ??.
View user's profile Send private message Send e-mail AIM Address
ROO90
PostPosted: Thu Jun 26, 2014 12:22 pm    Post subject: Re: Mercedes command Help Reply with quote
Yes have it all working now.
After you have downloaded the file , then extracted it you will see a file with
Need Help
Licence
Pocketgps uk mobile
Pocketgps-uk-sc GPX File ........this one only
Release
RENAME the Pocketgps-uk-sc GPX File only to PersonalPOI then copy or move to the PersonalPOI folder on the SD card
Good Luck worked for me
22.052 (08 May 24)
