Pocket GPS World :: View topic - Garmin 2595LM Locks up
HummerUK
PostPosted: Sun Mar 24, 2013 10:29 pm    Post subject: Reply with quote
Still not sure...
Today did a voice favourite find.
I picked the one by voice, then at the screen where it asks you to navigate or exit I said "navigate" but nothing happened.
Device locked up on that screen, tried unplugging power cable no change, and thus had to hold down the power button to clear the screen and it rebooted.
Been okay again since then.
HummerUK
HummerUK
PostPosted: Mon Mar 25, 2013 3:18 pm    Post subject: Reply with quote
Crashed again this morning turning off Sad
Perhaps an issue with the new maps?
Anyway, no time to sort out this week but if no fix soon I shall arrange a replacement.
HummerUK
HummerUK
PostPosted: Mon Apr 22, 2013 5:51 pm    Post subject: Reply with quote
New maps and software 7.90 out now...
Improved custom POI searching from the map POI list
Improved InstaSearch results in Russia
Improved route importing from Basecamp when the map versions match
Improved map matching when roads are close together
Fixed an error that caused route calculation times to lengthen over time
Fixed several layout errors for Right to Left languages
Fixed several errors with the keyboard grayout logic
FMI improvements
Improved software stability
Maps 2013.41
HummerUK
HummerUK
PostPosted: Thu Apr 25, 2013 9:29 am    Post subject: Reply with quote
7.90 has not stopped my unit turning itself off / crashing so I guess it's time to raise a RMA with Garmin Sad
HummerUK
locksmith
PostPosted: Mon Apr 29, 2013 9:05 pm    Post subject: Reply with quote
Just sent my 2495lmt back to garmin because it keeps turning off, and this is a replacement unit as the original was doing the same.
I asked if this was a common problem and got told no!
This unit would turn off either during navigation or not. If I unplugged the 12v supply and plugged it back in it would restart the unit, however the previousone you had to unplug it and press and hold the button to get it to switch back on.
So if this keeps happening and the original warranty end date passes, I take it it's ready for the dustbin and have to buy a TomTom?
HummerUK
PostPosted: Wed May 01, 2013 12:30 pm    Post subject: Reply with quote
I was getting a bit of both, sometimes just unplugging the cig plug would allow it to restart and other times I needed to hold the power button down (while trying not to crash).
I have not yet bothered to send it back, is it worth the effort I ask myself?
Prior to two software updates it never crashed once so I still suspect they have caused the problem in one of the "enhancements"
HummerUK
locksmith
PostPosted: Wed May 01, 2013 5:06 pm    Post subject: Reply with quote
A replacement is on it's way so we'll see what that does.
Wasn't much effort, one call to Garmin (tell them you've already done a master reset) and £1.20 first class post.
locksmith
PostPosted: Tue May 07, 2013 8:43 pm    Post subject: Reply with quote
The replacement was no better. Plugged it in and twice that afternoon it shut down.
Back on the phone to Garmin and after a long (decent) conversation we found one abnormal thing. The unit was displaying it had 7.7 software despite Garmin Express saying it had 7.9 installed.
I had to open Mygarmin dashboard where it let me update again and now the nuvi shows 7.9. (I did update the unit when it arrived).
Garmin said if it continues they will replace it with an upgraded model? 2595, thats just a bigger screen right?
Anyhow I used it for half an hour this evening and it hasn't shut down yet but I'm not holding my breath!
HummerUK
PostPosted: Tue May 07, 2013 10:34 pm    Post subject: Reply with quote
My one still poorly and I noted today the voice command menu had changed option names...
Prior to 7.90 it had "Recently Found" and now it is "History"
HummerUK
locksmith
PostPosted: Mon May 13, 2013 9:17 pm    Post subject: Reply with quote
3rd replacement 2495 on it's way back now. Shut down 3 times in 4 or five days.
They are sending me a 2595 Rolling Eyes
locksmith
PostPosted: Sat May 18, 2013 4:19 pm    Post subject: Reply with quote
Well 2595 arrived and day one was fine, day two and it's shut down three times. Only this one is a beast to wake back up. Have to unplug it and keep presing the button until it eventually wakes back up Confused
What a crock of sugar these models are.
HummerUK
PostPosted: Tue May 21, 2013 8:19 pm    Post subject: Reply with quote
Indeed, my one still does it and often when I pick a destination it will shutdown and it takes about another four tries before it will get to the accept screen without rebooting.
Then it will be okay as it was till a couple of software updates back.
I was wondering if it related to the traffic module or bluetooth but it still does it without the module and with BT disabled.
locksmith
PostPosted: Tue May 21, 2013 9:09 pm    Post subject: Reply with quote
Yes , i disabled BT as well in case it was a conflict.
locksmith
PostPosted: Mon Jun 03, 2013 9:16 pm    Post subject: Reply with quote
Bit of an update
Garmin started saying that the van I use it in may be giving voltage spikes that cause a fault in the unit so it kept shutting down in the other 2 vehicles I tried it in.
For some unknown reason I opened the box the nuvi came in and looked at the power lead. It had a red led instead of the green one on all the previous ones supplied. ( i didn't use this as I had tried 3 different power leads previously)
The newest one was a GTM35 as opposed to a GTM25.
I plugged this one in and the nuvi has performed faultlesly ever since.(touch wood).
So whats the difference?
locksmith
PostPosted: Mon Jul 01, 2013 8:40 pm    Post subject: Reply with quote
Just done a 1000 mile euro trip and the nuvi performed fautlessly
Page 2 of 3
