Newsletter
Pocket GPS World :: View topic - On ios 6 'also run' is missing coppilot
fredbloggs123
PostPosted: Thu Dec 27, 2012 4:47 pm    Post subject: On ios 6 'also run' is missing coppilot Reply with quote
I have just got an iphone 4s and in the CamerAlert settings the 'On startup also run' is missing 'Copilot'. It's only showing 'Nothing' or 'Maps'? How do I get it to show Copilot so that I can select that it starts copilot as my android version does.
PostPosted: Fri Dec 28, 2012 12:47 am    Post subject: Reply with quote
As far as I'm aware Co Pilot does not have the required custom URL scheme to be able to do this.
The easiest way to see if it does have one is to see if it has an option of emailing or sharing your location with other users. If it does then the link it sends to other iPhone's will show the URL scheme we need to use - it would be something like copilot://?lat=52.123&lon=2.123 or similar. The part we/you need is the copilot://
PostPosted: Fri Dec 28, 2012 12:48 am    Post subject: Reply with quote
OK, just checked - CoPilot 9 DOES have the sharing - you need to enter copilotv9:// to the also run text box. We will get this added in the next update, but for now you can enter it manually.
fredbloggs123
PostPosted: Fri Dec 28, 2012 3:51 am    Post subject: Sorted, MaFt you are a star! Reply with quote
Temp fix has done the trick. Amazed I'm the only one who has noticed!
Now if you can just design a way to exit CamerAlert instead of having to do the double home push thing. Wink
Thanks again.
PostPosted: Fri Dec 28, 2012 4:08 pm    Post subject: Re: Sorted, MaFt you are a star! Reply with quote
We did used to have an 'exit' button. But Apple rejected the app for it as it doesn't meet their guidelines. Feel free to fight it out with Apple yourself...
PostPosted: Fri Dec 28, 2012 4:09 pm    Post subject: Reply with quote
The other option is to turn off tracking (cross hairs at bottom left) and tap the home key. With the tracking turned off the app will be closed by the OS when the memory is needed.
19.031 (03 Mar 21)
