TD Occasional Visitor
Posted: Fri Oct 26, 2012 9:18 am Post subject: TomTom720 audio volume problem |
Hi My old TT 720 has served me well, but the volume has always had to be set to maximum. Having bought a motorhome now,I find it impossible to hear the TT above the engine
What has prompted this question is,I used a friends Tom Tom & the volume was far louder than mine
on mine the sound using the volume adjustment bar,does not come on until the 50% position is reached.
has any one had this problem rectified or can make any suggestions or recommendations please  |
DennisN Tired Old Man
Posted: Fri Oct 26, 2012 9:37 am Post subject: |
Is your friend's device also a 720? Anyway, they can vary, so that's no help, is it? Have you got an FM radio in the van? The 720 can transmit to it - change the speaker preferences and select an empty FM frequency (not 100% successful as you drive around, somebody will use the one you choose, but I found 80Hz best). Set the radio to that frequency. The problem is you can't listen to your favourite radio programme at the same time. _________________ Dennis
Two of them are obesiting!! |
Posted: Fri Oct 26, 2012 3:44 pm Post subject: |
Thanks for the reply,but I thought that you could only play through the car radio If you were using your TT to play music via its player/sd card, Then it would interrupt with voice directions??? |
Posted: Fri Oct 26, 2012 5:43 pm Post subject: |
One option is load a silent mp3 track to the TomTom then select that to play and repeat, this lets you use the FM Tx to play instructions over the radio without having music playing but it does prevent you from hearing the radio.
Another option (if you car supports A2DP Bluetooth) is to pair the TomTom to the car and select Bluetooth as the speaker option, this way (depending upon how the car handles the BT connection) will play the nav instructions via the car speakers and let you listen to the radio - Mike |
Posted: Fri Oct 26, 2012 6:28 pm Post subject: |
I was hoping to find a mount that also contained an external speaker but it seems that even if I use an audio lead from the TT to another speaker the Unit will only transmit voice instructions if music is being played
your suggestion of using a silent mp3 file seems to be the only option
as my van radio does not have a aux in socket.
thank you all |
theberties Occasional Visitor
Posted: Sat Oct 27, 2012 9:52 pm Post subject: |
in sound preferences have you got the "link volume to noise level " box ticked? if so untick it and volume will increase
bertie |
Posted: Sun Oct 28, 2012 9:40 am Post subject: |
Hi Bertie,thanks for the tip, yes I have it ticked
I will try your suggestion
TD |
Posted: Sun Oct 28, 2012 12:35 pm Post subject: |
when i downloaded latest map for some reason it automatically reverted back to link sound and volume was low low i had to turn radio off to hear the instructions. |
Andy_P Pocket GPS Moderator
Posted: Sun Oct 28, 2012 2:37 pm Post subject: |
Same here, but for me I think it got changed on the last software update rather than the map one. _________________ "Settling in nicely" ;-) |
