Pocket GPS World :: View topic - splash screen dimensions
dezwez
PostPosted: Mon Jul 09, 2012 9:51 pm    Post subject: splash screen dimensions Reply with quote
hi anyone know what size splash screen
are for the tomtom via 125 thanks in adv Smile
dezwez
Garmin Drive 50 LM 5"
dhn
PostPosted: Mon Jul 09, 2012 11:56 pm    Post subject: Reply with quote
Screen seems to be a 5" model. See here:
http://www.tomtom.com/en_ie/products/car-navigation/via-125-europe/#tab:specifications
dezwez
PostPosted: Tue Jul 10, 2012 7:01 am    Post subject: Reply with quote
thanks
dezwez
mostdom
PostPosted: Tue Jul 10, 2012 8:04 am    Post subject: Reply with quote
You might find our splash screen database of some use.
Dom
PostPosted: Tue Jul 10, 2012 12:18 pm    Post subject: Reply with quote
For all TomTom 4.3" and 5" widescreen models, actual screen size is not important, they are all 480x272 pixels resolution and so that's the native size for the spashscreens too.
For the old "NAV2" machines, the startup and shutdown screens have to be exactly those dimensions and in .bmp format and are called splashw.bmp and suspendw.bmp respectively.
However, for the new "NAV3" models that use MyTomTom (such as the VIA125) it's not so important. You can use any size you like, and in bmp or jpg format. Images that are too small will be scaled up, and images that are the wrong aspect ratio will be cropped. They can have any name you like.
The new 6" screen Start 60 is the only exception as it has a high resolution 800x480 screen, but it works just the same - any size image can be used (from 1x1 upto 1280 x 1024)
For anoraks:
On the old small-screen models it was 320x240 pixels and the startup screen was called splash.bmp.
On very early models and software, the image had to be rotated through 90 degrees before uploading it to the device, but that ended with v7 software IIRC.
"Settling in nicely" ;-)
dezwez
PostPosted: Tue Jul 10, 2012 12:28 pm    Post subject: Reply with quote
hi thanks so much that was a great help thanks Wink
dezwez
