robbiewrongway Occasional Visitor
Posted: Sun May 13, 2012 9:17 am Post subject: TT820 - installing low bridges and truckstop POI's |
I have just purchased a TomTom GoLive 820
i have just purchased Bridge hieghts and truckstops POI's from lowbridges.com and cant seem to install them!!. the instructions say to close MyTomTom copy and paste the poi files in the map folder of the device.... problem is... the device does not appear in My Computer window as a 'Drive'... it does however appear in Device Manager as a network adaptor but it does not appear in the Network window!! i am running win7 ultimate.... pleas help!!
EDIT: Slight change to subject to clarify. PaulB2005 |
AliOnHols Pocket GPS Verifier
Posted: Sun May 13, 2012 9:47 am Post subject: |
I think that you need to follow the guide here http://www.pocketgpsworld.com/uksafetycameras-tomtom-nav3-zip.php and start from instruction #4.
EDIT - Substituting your POIs for the PGPSW ones where appropriate.
MyTomTom is a web based program from TomTom.com which shall allow you to add POIs _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Sun May 13, 2012 1:02 pm Post subject: |
thanks for that..... have tried using the Add Community but it would not let me install a .zip file.... i believe the .ov2 and .bmp files have to be placed in the Map folder and not the .zip folder itself.... only problem is, there is a lot of these files for every configeration of hieghts!! please dont tell me i have to install them all individually !!!
Thanks in advance
Rob |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Sun May 13, 2012 2:20 pm Post subject: |
robbiewrongway wrote: | . . . it would not let me install a .zip file |
I've never used My TomTom as my 5-year-old 720 is still going strong, but with older TT devices you have to unzip the file before installing it. If you're running Windows, right-click the zip files and select 'Extract all', then install the resulting .ov2 and .bmp files. I've no idea if you have to instal them individually on the 820.
The instructions AliOnHols linked to don't tell you to unzip the file, so I may be talking rubbish (not unusual!) but it would be worth a try till someone with experience of MyTomTom replies. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15143 Location: Bradford, West Yorkshire
Posted: Sun May 13, 2012 3:12 pm Post subject: |
don't they provide support for their own POIs on their site? seem a bit odd to have to come to a competitor's site to ask how to install them ;)
we also have low bridge data but it's only available as part of our subscription package (which also includes access to the speed camera database).
anyway, if you have the latest firmware and latest version of MyTomTom then you should be able to upload a single zip file to put everything in one go. However, it will only work if (and only if) there are only ov2, bmp or ogg files in the zip.
MaFt |
Andy_P Pocket GPS Moderator
Posted: Sun May 13, 2012 6:06 pm Post subject: |
robbiewrongway wrote: | thanks for that..... have tried using the Add Community but it would not let me install a .zip file.... i believe the .ov2 and .bmp files have to be placed in the Map folder... |
Correct - they go into the NAMED map folder (Western Europe, Europe, UK and Ireland, or whatever yours is called) NOT a folder called "map".
robbiewrongway wrote: | and not the .zip folder itself.... |
Definitely not... The "zip" folder is nothing to do with zip files, its to do with postcodes (the folder was confusingly named after American "zipcodes")
robbiewrongway wrote: | only problem is, there is a lot of these files for every configeration of hieghts!! please dont tell me i have to install them all individually !!!
Get used to it!
But you only have to install them one at a time if you use Internet Explorer as your normal web-browser (the MyTomTom program uses your web-browser for its screen display).
If you use Firefox or one of the others, you should be able to select all the individual files in one go and MyTomTom will install them all in one go. (See those instructions that AliOnHols linked to)
MaFt wrote: | f you have the latest firmware and latest version of MyTomTom then you should be able to upload a single zip file to put everything in one go. However, it will only work if (and only if) there are only ov2, bmp or ogg files in the zip.
MaFt is right here, plus a few people seem to have problems with this method anyway (it's quite new).
The "normal" method that has worked for years is to install all the .ov2 and .bmp files as above. _________________ "Settling in nicely" ;-) |
