Pocket GPS World :: View topic - blown fuses
blown fuses
ivanackeroff
PostPosted: Fri Apr 06, 2012 10:18 am    Post subject: blown fuses Reply with quote
My cigar lighter fuse keeps blowing! my Skoda garage blames my Garmin 1490t sat nav. I have used sat navs for years without this happening.
Could they be correct? Confused Confused
glossyballs
PostPosted: Fri Apr 06, 2012 11:17 am    Post subject: Reply with quote
Not if everything is working as it should (but then you knew that!)
I would have thought the Garmin charger should be pulling a maximum of 1.5 to 2 Amps from the car electrics, and the fuse is probably rated at around 10 Amps. So it sounds like something is actually shorting out the cigar lighter circuit, rather than just pulling a bit too much power.
Have you tried the obvious experiments like driving for a while without it plugged in at all, or with JUST the charger plugged in and without the Garmin itself on the end of it?
And do you have anything else with a cigar lighter power plug (like a phone charger) that you could try in it's place?
"Settling in nicely" ;-)
PostPosted: Fri Apr 06, 2012 12:31 pm    Post subject: Reply with quote
Well it's not your 1490 if everything is working correctly Wink
Mine has never blown a fuse.
As Andy suggests, there must be a fault somewhere ... either in your 12V socket or in the nuvi cable, or possibly the nuvi itself. Have you tried in in another car to see if it blows a fuse there?
ivanackeroff
PostPosted: Fri Apr 06, 2012 2:59 pm    Post subject: blown fuses Reply with quote
Thanks for that lads it is 15 amp so don't see it possible
glossyballs
PostPosted: Fri Apr 06, 2012 6:20 pm    Post subject: Reply with quote
When my Renault van blew a fuse they first tried to suggest it was my plugins setup (just because I have five things plugged in all the time! - two satnavs, two iPhone mounts and a tracker Rolling Eyes ).
But it wasn't. My fuse housing had a dodgy seal and water got in and blew one, together with several things like number plate light, part of the dashboard and one rear side light.
It took them (the dealership, who know how to deal with stuff Confused ) two hours to open the thing up and replace the fuse. It was nice knowing the van was under warranty. Very Happy
22.052 (08 May 24)
