Pocket GPS World :: View topic - Tomtom 520 loses satellite signal
mwfox
PostPosted: Fri Oct 28, 2011 5:15 am    Post subject: Tomtom 520 loses satellite signal Reply with quote
My Tomtom 520 reguarly loses satellite signal and then can no longer be used. I have tried holding the reset button for 20 seconds then the power button, but this doesn't seem to fix it. Then later on it will start working again for a short while. Another GPS device works fine in the car.
I have made a backup using Tomtom Home.
Has anybody else had this problem and managed to fix it or does it sound like a hardware failure?
dhn
PostPosted: Fri Oct 28, 2011 11:25 am    Post subject: Reply with quote
If you connect to the computer and use Explorer to delete anything in the ephem folder on the unit and then go here:
c:\documents and settings\yourname\my documents\TomTom\Home\Downloads\Complete\ephemeris\
and delete any sub-folders found there, then connect to Home, you should get a new gpsquickfix file.
Install and disconnect from Home properly using the Device Disconnect icon. See if that helps.
mwfox
PostPosted: Sat Oct 29, 2011 10:19 am    Post subject: Reply with quote
No unfortunately that didn't improve things. It seems to lose GPS signals quickly and then doesn't get it back again.
dhn
PostPosted: Sat Oct 29, 2011 10:35 am    Post subject: Reply with quote
Do you by chance have a vehicle with an athermic windscreen? They sometimes play havoc with gps signals.
PostPosted: Sat Oct 29, 2011 10:38 am    Post subject: Reply with quote
Does it lose signal whilst actually in use or is it just very slow to get a signal on start-up?
Might also be worth running ClearFlash, see here.
mwfox
PostPosted: Sun Oct 30, 2011 6:41 am    Post subject: Reply with quote
Thanks for your replies. No just got a standard windscreen. It does lose the signal whilst in use and now is proving impossible to get a signal on startup. I have also tried deleting the Tomtom app and reinstalling it using HOME. Tried the clear flash tool as well all with no luck.
Should the yellow and black circle rotate when on GPS status mine is frozen?
PostPosted: Sun Oct 30, 2011 7:41 am    Post subject: Reply with quote
It rotates to show that it's searching for the satellite signals. I don't think it ever stops (normally).
PostPosted: Sun Oct 30, 2011 9:42 am    Post subject: Reply with quote
If the little circle has stopped the unit isn't receiving any GPS data, either the aerial has died/ disconnected, either way there isn't anything you can do - Mike
22.052 (08 May 24)
